[RELEASE] Aeon RGBW LED Bulb Advanced Device Handler
What does the ‘recently’ tab tell you from the device page? What triggered it to turn on?
All the recently tab says is “Balcony turned on… 7:15”
That’s it, seemingly all by itself. Its been 3 mornings now, all around the same time, without an obvious trigger.
It’s either a power cut or you have an automation then somewhere that’s turning them on if it’s at the same time every morning.
Looks like it could be a sunrise specific time…
It started Sunday at 744, Monday at 812, Tuesday at 710 and this morning at 715.
It’s been rock solid for a year. The only automation it has is to come on at sunset, and off at “Good Night”.
Yesterday I tried changing the DH to the default one, but no joy. Is there a way to factory reset this device?
Hey, the only routines are to turn on at sunset, and it’s in my Good Night routine to turn off.
It’s associated with Alexa also. That’s it.
Yesterday I factory reset it, re-included it into the network, and set same automatons.
It turned on AGAIN by itself yesterday at 1541 and today at 1643!
So I’ve had to create a CoRe piston that turns it off when it comes on when it shouldn’t and send me a notification. Slightly counterintuitive.
Power fluctuations maybe?
You could try to exclude it from the network and just leave it as a dumb bulb for a day or two. If it still does the same thing and it isn’t linked up to SmartThings at all then it would have to be a flaky bulb.
I’m trying to use this device type, but it seems the preset buttons (like police, fade, etc) aren’t working for me. I also noticed my firmware version is listed as v54238. I did go into the Preferences and press Done to no avail.
Hi Eric, and thank you for the Device handler, if it weren’t for you and your multiple device handlers, I wouldn’t be a ST user to day.
Regarding this Aeon RGBW LED handler there is one para meter I need to change and I was hoping you could help me set it.
It refers to use a wall mounted push button (Always On) to turn the Bulb on and off.
I need to set Parameter 34 to 1
Can you please help, ether to tell me where I can change the code so this will work or change your code so this will be an option in the parameter listing.
Manually Toggle LED Bulb ON and OFF using the External Switch.
In order to manually toggle the LED bulb ON and OFF using the external switch, you will need to use:
Parameter 34 [1 byte].
Value 0 = Disable [default]
Value 1 = Enable
Once this configuration setting has been set to 1, you will be able to control the state of your LED bulb using your external toggle switch by
Quick toggle OFF → ON within 1 second
This will toggle ON and OFF state of LED Bulb
Best Regards and thank you for all your hard work.
Þorgeir Valur Ellertsson
Iceland
I don’t quite understand what the “External Switch” is that this parameter is referring to, but I did add the parameter for you. Do you have a link to which switch you are using?
I am not shore how to explain it properly but I will try.
By turning this switch on I can use a reverse momentary switch. Now I have a constant power to the bulb, but when I turn it off for 1 second pushing a pushbutton on the wall (which I have reversed) I can turn the bulb on/off with out it being disconnected from the network. Now I don’t need to buy a Z-Wave switch to turning it on and off by hand.
Hope you under stand me.
Thank you so much it works like a charm.
Þorgeir Valur
I think… it’s referring to a way of turning the bulb OFF (in software) but keeping it powered on (physical light switch) by using the physical light switch.
So for example the light is currently on (emitting light), I want to turn it off but keep it physically powered on however, I don’t have my phone or anything to tell ST (or whatever hub it’s connected to) but I can flip the light switch in a certain way that will turn it off but allow me to keep it physically powered on.
It looks like this configuration parameter enables that toggle action.
Does that make sense @Bjorkollur? Is that what it does?
Yes exactly :grinning:
Ok, I think I see. So you quickly toggle the switch the bulb is connected to and it will turn it off instead of the bulb turning off and coming back on. I guess I didn’t think about the bulb being able to distinguish that type of toggle.
I’m probably preaching to the choir but just so everyone else knows as well, you can actually change the bulb colour via the physical light switch as well :slight_smile:
Hi,
I’m a bit of a newbie to Smartthings - How do I use this devicehandler.
I essentially created a device handler and pasted in this code.
What are the next steps?
Kind regards,
Sanu
Once ‘installed’ properly, you can pair up the bulbs. It’s possibly they may still pair up using the stock DTH and you might have to go in and manually change it.
Works perfectly now.
Thanks Robin!
Hi - I’ve recently bought one of these to go alongside a Lightify RGBW in a couple of table lamps. I use a Virtual Dimmer switch to control them both in sync. Worked great when I had two Lightifys, but these don’t play nicely together… The main problem is with Color Temp - the Virtual Dimmer and Lightify both work on Kelvins, but this DTH seems to work on a number between 1 and 100.
Any ideas how I can make them play? Either by changing the scale from 100 to Kelvins or doing some maths somewhere to convert on the fly???
You have two options:
  1. Learn Groovy and try and do it yourself.
  2. Ask @erocm1231 really really really nicely and see if he can help out.
