Hi Eric and all,
I’m having a problem with the Aeon Multisensor 6 where it is taking one hour to report changes like humidity and temperature, even though I have it set to 300 seconds (5 minutes). This is a new sensor I recently bought that has firmware v1.12. My region is the US. It has DTH 7/20/18 running: EDIT - Not sure this is the latest - see note at bottom.
When I look at the “Recently” events it shows updated temp and humidity at 1:59 AM today, 2:59 AM, 3:59, and every hour x:59. It had been working fine until I decided to change the reporting interval to 1800 (which is still every half-hour, not every hour) as a test. But then after changing it back it stays at every hour.
This is creating a big problem for me, since I need much more frequent reporting intervals (every 5 minutes) to properly control a dehumidifier (I use this sensor as my humidistat).
Here are my settings:
Battery
Selective Reporting: NO
Temp thres: 20
Humidity thres: 10
Lumin thres: 100
Battery thres: 10
Ultrav thres: 2
PIR reset time: 256
PIR motion sensitivity: 0
Reporting interval: 300
Temp offset: 0
Humidity offset: -1
Lum offset: [not set]
Command set: Basic Set
LED Options: Fully Disabled
Stay Awake Time: 30
Region Override: Off
Enable Debug Logging: ON
Here are the Preferences settings inside the Device data within the SmartThings IDE:
Name | Type | Value |
paragraph | ||
101 | enum | 241 |
111 | number | 300 |
201 | decimal | 0 |
202 | number | -1 |
203 | number | |
204 | number | |
3 | number | 256 |
4 | number | 0 |
40 | enum | 0 |
41 | number | 20 |
42 | number | 10 |
43 | number | 100 |
44 | number | 10 |
45 | number | 2 |
5 | enum | 1 |
8 | number | 30 |
81 | enum | 2 |
enableDebugging | boolean | true |
regionOverride | enum | 0 |
From what I understand, since I have Selective Reporting off, and Reporting Interval at 300, this should reporting at least the latest humidity and temperature every 300 seconds, yes?
Is it possible that despite these settings, the sensor itself has not seen these settings/configuration and is using something else? First I tried making the changes in the SmartThings app to the device using the Gear icon, changing the values to the above, and then pressing Save. Then I tried doing things like pressing the “rewind” arrow on the device’s “tile” (that the DTH displays) in the app. Then I also tried pushing the Config tile in the app. Then I also tried pushing the button (press down for a single click and let go, light turns green for a little bit) on the back of the sensor to wake it up, then make the changes and hit save. I also tried pushing the “rewind” and Config options on the tile after I woke it up.
What’s the proper approach here to force the sensor to reload it’s config. Should any/all/some of the above already have forced it to reload it’s config? Maybe I’m not doing something right here. Is there something else I should try? There is the Stay Awake time which looks like it can be helpful, but the help for this parameter says it only works with firmware v1.08, unless this should say v1.08 and higher?
It’s been 8 hours (or maybe as much as 12 or 16 hours, can’t recall what time yesterday I made the changes) and it still has not taken affect. The docs here say if you want the change to take affect immediately just press the button on the back of the sensor, but as you can see from my notes above, I did try that. After I press the button it did send/update the latest time/temp, but then it still waits a hour before sending the next updates each time. Before I changed the settings yesterday from 300 to 1800 it was working just fine. Now I can’t get it back to that state.
How can I troubleshoot this further and what else can I try please?
EDIT: After reading through all these posts I see you said you published a few updates a few months ago. However the Github shows: 2018-07-20 5:26 PM. So I’m confused what version I actually have as the source does not have version numbers in it. Which is the latest?
EDIT 2: I then though I came across an update from 2018-08-20 somewhere but get all sorts of errors when I hit Save. I use Raw from the github. Copy/paste it into the DTH code window replacing everything that was there. When I hit save I get a red background in the code window and dozes of errors like these:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
script_dth_metadata_41995063_86e6_4552_a60d_4572374ec8b1: 209: unable to resolve class hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation
@ line 209, column 16.
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
script_dth_metadata_41995063_86e6_4552_a60d_4572374ec8b1: 220: unable to resolve class hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport
@ line 220, column 16.
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
script_dth_metadata_41995063_86e6_4552_a60d_4572374ec8b1: 224: unable to resolve class hubitat.zwave.commands.configurationv2.ConfigurationReport
@ line 224, column 16.
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
With hindsight I think this 2018-08-20 code may have been from someone besides Eric so I am disregarding it for now and assuming 2018-07-20 is the latest.
Edit 3: In looking at the first post in this thread, my tiles look a little different than pictured there. Maybe that pic is outdated or my version is outdated. MY bottom middle tile says “Configure” and shows a wrench/screwdriver icon. Whereas in your picture it shows SYNCED. Although as mentioned in detail above, I’ve tried everything imaginable to get it to sync so I am not sure if it really is not sycned or it is but the tile does show as such.
Edit 4: Just as a test I switched the Aeon Multisensor 6 over to USB powered and even with it set to update once every 30 seconds it still is only updating once per hour. Is this DTH tested with firmware 1.12? I’m not sure how new it is and whether that is the issue?
Edit 5: I have an older Aeon Multisensor 6 here that I was trying to replace with this new one (my older one has a bad battery terminal so I can only use one battery). I just re-added the older one back into ST and its updating every 5 minutes, no problem. The main difference I can think of is that this older one is running firmware 1.10. In an earlier post I think Eric said something about how the reporting times sometimes require a change in the DTH after a firmware update so maybe that is the root cause here? I think I’m (finally) out of things to try!
Edit 7: Another indication that somehow the settings are not “sticking” or getting to the sensor is that I also have PIR Motion Sensitivity at 0 to disable it, but it keeps reporting motion every time I walk by it. Whereas my older sensor (with the 1.10 fw) with this same setting does not report any motion at all, as expected.
Edit 8: I excluded the new sensor from ST, did a factory reset on it, set it up all over again and still have the same exact issue. Documentation says I can configure it with USB power easier, so I tried that. It seems to accept the 300 reporting interval but still only sends the temp and humidity once an hour:
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:24:37 PM: debug No commands to send
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:24:37 PM: debug Device Aeon MultiSensor 6 New2 woke up
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:20:07 PM: debug NotificationReport: NotificationReport(eventParametersLength: 0, eventParameter: [], zensorNetSourceNodeId: 0, v1AlarmType: 0, reserved61: 0, notificationStatus: 255, sequence: false, event: 0, notificationType: 7, v1AlarmLevel: 0)
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:20:07 PM: debug BasicSet: BasicSet(value: 0)
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:19:37 PM: debug No commands to send
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:19:37 PM: debug Device Aeon MultiSensor 6 New2 woke up
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:14:39 PM: debug WakeUpIntervalReport WakeUpIntervalReport(seconds: 300, nodeid: 1)
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:14:37 PM: debug VersionReport(applicationVersion: 1, zWaveLibraryType: 3, applicationSubVersion: 12, zWaveProtocolSubVersion: 54, zWaveProtocolVersion: 4)
[3d9f915a-def5-409f-xx](https://graph.api.smartthings.com/ide/logs#3d9f915a-def5-409f-xx) 9:14:36 PM: debug Setting Wake Interval to 300
So is IS waking up every 5 minutes, however it is not reporting the latest temperature and humidity, which most certainly is changing, at least by a fraction. And as a reminder, Selective Reporting is set to Disabled so I am expecting these updates.
Thank you!!
