Thank you!
@BartschLabs, after redoing some of the updates, unpairing/re-pairing the sensors with my hub, and adjusting some of the Temp/RH offsets I now have somewhat functional sensors.
That is for five of the six sensors I have. The sixth one completely refuses to update to v1.10. The DTH indicates the device is still on v1.08 despite multiple āsuccessfulā update attempts using the Z-Stick (both directly paired and while in my SmartThings network). This last sensor has now bizarrely started flipping light switches that I put it next to (even after removing it from my network). I finally had to pull its batteries and am waiting on Aeotec to send me v1.08 of the firmware (which I can no longer find on their site) so I can try flashing that back onto the misbehaving sensor.
Overall the light measurements from the sensors running the v1.10 firmware actually make sense now and are usable. If you donāt use that functionality I recommend not bothering with this PITA update process.
Over a month on did you ever get the 6th one working?
@tmleafs, I couldnāt get the last sensor to function properly with the v1.10 firmware; however, Aeotec support sent me a copy of the older v1.08 firmware which got the device back to working order.
Hi,
@erocm1231, thank you for a really good device handler.
I have a question, is there some way to call the refresh functionality, within this device handler, from within a SmartApp? E.g. when a SmartApp is manually started, it first refreshes the sensor values and then checks, for example, the temperature, to get an exact reading for the moment being.
Thank you in advance.
Iām not sure if there is a SmartApp out there that specifically does this. It could easily be done with WebCoRE. If the device is battery powered though, the refresh isnāt going to work as the device will be asleep.
Hi Yuri,
If you had them connected with FW v1.08 before, was motion detection working well for you?
I have two of these sensors, both on v1.08 an both of them donāt detect any motion. They detect once when you power them on, and after that no response whatsoever. I think the interface is great and all other things work fine (except for the configuration button, only showing a red dot and no other response when clicked) I was just about to order a z-wave stick, hoping the v1.10 firmware would fix things, but I see you have problems with this version.
Would perhaps downgrading to version 1.07 work better? Anyone?
Only if ST choose the implement it. Its not something you can control in the DH
That sucks! The standard DH is poor!
Hi all, I started using @erocm1231 's DTH for my aeon 6 multi sensor. all sensors working except motion. it was working well earlier but stopped suddenly reporting motion . Any idea on why could that be ?
Fab
Thank you so, so much for creating this device handler, @erocm1231, I just found it! I honestly think Aeotec should be paying you a royalty for every instance used.
Did you ever figure this out. Mine is also no longer sending motion related alerts.
I excluded it and then included it again. It worked then. Hope that helps
Thanks that actually worked!
mine only intermittently reports motion as well. I really hate Aeotec. I donāt have a single device by these people that works well.
Anyone else having issues with this DTH lately?
I get āTiles Missingā where the device name should be on both my Aeon M 6 sensors
I am using the ver from @MichaelS and it just started within the last few hours.
I also see this same thing on all 4 of my Aeon Aeon Minimoteās.
Talking to the techs right nowā¦It is at SmartThings and is being worked onā¦mine failed as well
Okā¦they are posting the fix and mine started working.
Mine as well.
Thank you!
