When you pair the device, make sure you’re close to the hub and you tap the action button multiple times while it’s looking for the device because that should make it pair securely.
It should still work when not paired securely, but the beep feature is more reliable when it is.
Hi, I am a newbie and based on suggestion in a different thread I got a aeon labs siren and this custom device handler to solve my scenario - i.e. “In addition to the regular siren, I want a beep sound everytime any door is opened irrespective of the ST Hub mode” .
It looks like the Rule Machine is not available any more and you have no way to configure conditional rules like “sound a beep when door opens” rule. any suggestion for an alternative approach or how to solve this?
CoRE is great, but it’s not necessary to make the siren beep when you open a door. This can be done with Smart Home Monitor and/or Speaker Notify with Sound.
I believe this Device Type isn’t functioning properly for me. I installed a Gen 5 Aeon Labs Multifunction Siren on Friday. I initially installed it with the ST device type, realizing it didn’t have all the functionality I looked for, I uninstalled it and reinstalled your device type by adding your git repo to the IDE.
Beeps 1,2 & 3 all sound the same. One constant ~2 sec beep. Beeps 4,5 & 6 are 3 ~2 sec beeps with 1 to 2 secs between them. Changing the volume on either the siren or beep doesn’t seem to do anything unless vol 1 and vol 3 aren’t much different. Changing the length of beep in ms or time between beeps in ms also has no effect. Changing beep repeat works just fine.
I tried removing the device from all smartapps, deleting it from the IDE, power cycled my v1 hub, added the device type back in, but it behaves exactly the same. Any suggestions would be greatly appreciated!
Edit - so I busted out my SPL and did measure a 10db difference volume 1 and 3. It’s much more noticeable when you’re in the same room. I also used tried setting a custom beep in Smart Alarm Notification to 3,1,2,500,50 and again duration of beep and duration between beep are not working.
A lot of users have trouble getting the device to pair securely and if it’s not paired securely, the beep feature will be unreliable.
Having the device close to the hub and tapping the action button multiple times during the pairing process should make it pair securely, but it sometimes takes several attempts.
However, I use this custom message in the “speaker play sound” smartapp: 4, 3, 1, 500, 1000 and it doesnt play beep 4… it plays a different tone and I can’t identify which it is. I’m trying to get 3 quick chimes for a door open alert.
Is it possible to somehow “Trick” the siren into using a single chirp sound and making it repeat it three times very quickly? I could probably fiddle with this for an hour or two playing with it, but figured I’d just ask.
You basically have it set to play sound 4 for 1 second, but it doesn’t start playing from the same spot so you could end up with no sound if it was between beeps or with a partial beep.
Sound 3 is a continuous tone so it’s the most reliable. Based on what others have reported, if your device isn’t paired securely, the beep feature will be so unreliable that it’s practically useless.
The line below should beep 3 times at volume 3 and each beep should last about 100ms and there should be about 250ms pause between them. If you’re device is paired securely, you should find it somewhat reliable, but it’s far from perfect
Thank you, I will try that right now. How can I be sure that it’s paired “Securely”? I just installed your device handler, paired the siren, then assigned the handler to the siren.
So for the past month the siren has been working fairly well. Less than a week ago it started acting like it did before it was connected securely. No matter what I set in the device settings the only setting that works is the number of beeps. Duration, duration between, volume, etc stopped working. I wondered if the device stopped communicating securely, but the logs still show the following.
Has anyone seen this happen before? I noticed it started to become less and less reliable for the few days before this occurred. Duration and time between would be all wacky. Any assistance would be greatly appreciated!
I’ve been noticing a lag with all my devices lately. I’ve never had reliability issues with the Aeon Siren, but my GoControl siren has been really bad for about a week.
I’m thinking it’s another stability problem with the ST platform which will hopefully improve soon.
My other device that was having a similar problem seems to be back to normal.
Have you seen any improvement since you posted this?
Unfortunately I haven’t. I still have no control over any setting except the number of beeps. I think I’ll be removing the device and reinstalling it over the weekend. I should probably look into a different device for audible notifications. What are your thoughts on the Aeon Labs door bell? Is that a lot more reliable for door chimes?
