I suche eine Möglichkeit einen Reisemodus zu aktivieren bei dem man Startdatum und Enddatum eingeben kann, sodass in dieser Zeit exakte diese Routine abläuft ….Wer kennt sowas?
You can probably utilize the calendar function of this driver (EDGE Driver-Mc): Aplicaciones Virtuales Mc (virtual Switch Mirror, Virtual Calendar and virtual Switch Board...) but it would likely be easier to do either 1) simply include Location mode as a precondition in your Routine and change the mode when you are traveling; or 2) create a virtual switch to represent when you are traveling, include it as a precondition in your Routine, and turn it on/off when you are traveling. In both cases you could use another Routine to change the mode or turn on the switch based on member location. For example, change location mode to traveling when member location is away for 24 hours.
