Refresh does not work with device types
I’ve customized the thermostat to add battery and auto clock set functions which get the value every 1440 minutes.
As part of it Ive modified the Refresh button to do a “refresh” instead of a poll (this refresh function reset the 1440 minutes to now).
So the changes made are:
    capability "Refresh"
and
    standardTile("refresh", "command.refresh", inactiveLabel: false, decoration: "flat") {
		state "default", action:"refresh.refresh", icon:"st.secondary.refresh" // CUSTOMIZATION
These are taken from the documentation.
@bflorian just wanted to bring this to your attention, Refresh never works. If I use the above as given by the documentation the refresh function is never called. For it to work, I need to remove the capability line, modify to “device.refresh” and modify the action to just “refresh” and then it works.
Is this a bug or is the documentation incorrect or am I doing something wrong here?
Infact the standardTile code also work if I just remove the capability Refresh. The moment the capability line is introduced it stops working
Works for me WITH the capability “refresh” line:
    standardTile("refresh", "command.refresh", inactiveLabel: false) {
        state "default", label:'refresh', action:"refresh.refresh", icon:"st.secondary.refresh-icon"
Here’s my device metadata header:
metadata {
    // Automatically generated. Make future change here.
    definition (
        namespace:     "Green Living",
        category:     "Green Living",
        author:     "Barry A. Burke"
        capability "Energy Meter"
        capability "Power Meter"
        capability "Configuration"
        capability "Sensor"
        capability "Polling"
        capability "Battery"
        attribute "energy", "string"
        attribute "power", "string"
        attribute "volts", "string"
        attribute "voltage", "string"        // We'll deliver both, since the correct one is not defined anywhere
        attribute "amps", "string"
        attribute "energyDisp", "string"
        attribute "energyOne", "string"
        attribute "energyTwo", "string"
        attribute "powerDisp", "string"
        attribute "powerOne", "string"
        attribute "powerTwo", "string"
        attribute "voltsDisp", "string"
        attribute "voltsOne", "string"
        attribute "voltsTwo", "string"
        attribute "ampsDisp", "string"
        attribute "ampsOne", "string"
        attribute "ampsTwo", "string"
        command "reset"
        command "configure"
        command "refresh"
        command "poll"
        command "toggleDisplay"
// v1        fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
        fingerprint deviceId: "0x3101", inClusters: "0x70,0x32,0x60,0x85,0x56,0x72,0x86"
Do you also have a command “refresh” declaration?
Yep this is what I included
    command "refresh"
The moment I delete these 2 lines it works great, the moment I include them it stops
This is the reference documentation:
http://docs.smartthings.com/en/latest/device-type-developers-guide/building-z-wave-device-types/z-wave-device-reference.html
Here is the whole code if anyone’s interested. This is working, if I put the capability in it it stops working.
metadata {
	definition (name: "Thermostat with Temperature, Humidity and Auto Time setting", namespace: "rboy", author: "RBoy") { // CUSTOMIZATION
		capability "Actuator"
		capability "Temperature Measurement"
		capability "Relative Humidity Measurement"
		capability "Thermostat"
		capability "Sensor"
		command "switchMode"
		command "switchFanMode"
        command "quickSetCool"
        command "quickSetHeat"
        // CUSTOMIZATION
        command "heatLevelUp"
		command "heatLevelDown"
		command "coolLevelUp"
		command "coolLevelDown"
        // END CUSTOMIZATION
		fingerprint deviceId: "0x08"
		fingerprint inClusters: "0x43,0x40,0x44,0x31"
	// simulator metadata
	simulator {
		status "off"			: "command: 4003, payload: 00"
		status "heat"			: "command: 4003, payload: 01"
		status "cool"			: "command: 4003, payload: 02"
		status "auto"			: "command: 4003, payload: 03"
		status "emergencyHeat"	: "command: 4003, payload: 04"
		status "fanAuto"		: "command: 4403, payload: 00"
		status "fanOn"			: "command: 4403, payload: 01"
		status "fanCirculate"	: "command: 4403, payload: 06"
		status "heat 60"        : "command: 4303, payload: 01 01 3C"
		status "heat 68"        : "command: 4303, payload: 01 01 44"
		status "heat 72"        : "command: 4303, payload: 01 01 48"
		status "cool 72"        : "command: 4303, payload: 02 01 48"
		status "cool 76"        : "command: 4303, payload: 02 01 4C"
		status "cool 80"        : "command: 4303, payload: 02 01 50"
		status "temp 58"        : "command: 3105, payload: 01 22 02 44"
		status "temp 62"        : "command: 3105, payload: 01 22 02 6C"
		status "temp 70"        : "command: 3105, payload: 01 22 02 BC"
		status "temp 74"        : "command: 3105, payload: 01 22 02 E4"
		status "temp 78"        : "command: 3105, payload: 01 22 03 0C"
		status "temp 82"        : "command: 3105, payload: 01 22 03 34"
		status "idle"			: "command: 4203, payload: 00"
		status "heating"		: "command: 4203, payload: 01"
		status "cooling"		: "command: 4203, payload: 02"
		status "fan only"		: "command: 4203, payload: 03"
		status "pending heat"	: "command: 4203, payload: 04"
		status "pending cool"	: "command: 4203, payload: 05"
		status "vent economizer": "command: 4203, payload: 06"
		// reply messages
		reply "2502": "command: 2503, payload: FF"
	tiles {
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'${currentValue}°',
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
        // CUSTOMIZATION
		standardTile("mode", "device.thermostatMode", inactiveLabel: false, canChangeIcon: true) {
			state "off", label:'${name}', action:"switchMode", nextState:"to_heat", icon: "st.Outdoor.outdoor19"
			state "heat", label:'${name}', action:"switchMode", nextState:"to_cool", icon: "st.Weather.weather14", backgroundColor: '#E14902'
			state "cool", label:'${name}', action:"switchMode", nextState:"...", icon: "st.Weather.weather7", backgroundColor: '#003CEC'
			state "auto", label:'${name}', action:"switchMode", nextState:"...", icon: "st.Home.home1"
			state "emergencyHeat", label:'${name}', action:"switchMode", nextState:"...", icon: "st.Weather.weather2", backgroundColor: '#E11102'
			state "to_heat", label: "heat", action:"switchMode", nextState:"to_cool"
			state "to_cool", label: "cool", action:"switchMode", nextState:"..."
			state "...", label: "...", action:"off", nextState:"off"
		standardTile("fanMode", "device.thermostatFanMode", inactiveLabel: false, canChangeIcon: true) {
			state "fanAuto", label:'${name}', action:"switchFanMode", icon: "st.Appliances.appliances11"
			state "fanOn", label:'${name}', action:"switchFanMode", icon: "st.Appliances.appliances11", backgroundColor: '#02E181'
			state "fanCirculate", label:'${name}', action:"switchFanMode", icon: "st.Appliances.appliances11", backgroundColor: '#02D2E1'
		valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "heat", label:'${currentValue}° heat', backgroundColor:"#ffffff"
		valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "cool", label:'${currentValue}° cool', backgroundColor:"#ffffff"
		standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
			state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
         // CUSTOMIZATION
		standardTile("heatLevelUp", "device.heatLevelUp", inactiveLabel: false, decoration: "flat") {
                        state "heatLevelUp", label:'  ', action:"heatLevelUp", icon:"st.thermostat.thermostat-up"
        standardTile("heatLevelDown", "device.heatLevelDown", inactiveLabel: false, decoration: "flat") {
                        state "heatLevelDown", label:'  ', action:"heatLevelDown", icon:"st.thermostat.thermostat-down"
        standardTile("coolLevelUp", "device.coolLevelUp", inactiveLabel: false, decoration: "flat") {
                        state "coolLevelUp", label:'  ', action:"coolLevelUp", icon:"st.thermostat.thermostat-up"
        standardTile("coolLevelDown", "device.coolLevelDown", inactiveLabel: false, decoration: "flat") {
                        state "coolLevelDown", label:'  ', action:"coolLevelDown", icon:"st.thermostat.thermostat-down"
        valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
			state "battery", label:'Battery ${currentValue}%', backgroundColor:"#ffffff"
        valueTile("humidity", "device.humidity", inactiveLabel: false, decoration: "flat") {
			state "humidity", label:'Humidity ${currentValue}%', backgroundColor:"#ffffff"
        main "temperature"
		details(["temperature", "mode", "fanMode", "heatLevelUp", "heatingSetpoint", "heatLevelDown", "coolLevelUp", "coolingSetpoint", "coolLevelDown", "battery", "humidity", "refresh", "configure"])
def parse(String description)
	def map = createEvent(zwaveEvent(zwave.parse(description, [0x42:1, 0x43:2, 0x31: 3])))
	if (!map) {
		return null
	def result = [map]
	if (map.isStateChange && map.name in ["heatingSetpoint","coolingSetpoint","thermostatMode"]) {
		def map2 = [
			unit: getTemperatureScale()
		if (map.name == "thermostatMode") {
			state.lastTriedMode = map.value
			if (map.value == "cool") {
				map2.value = device.latestValue("coolingSetpoint")
				log.info "THERMOSTAT, latest cooling setpoint = ${map2.value}"
			else {
				map2.value = device.latestValue("heatingSetpoint")
				log.info "THERMOSTAT, latest heating setpoint = ${map2.value}"
		else {
			def mode = device.latestValue("thermostatMode")
			log.info "THERMOSTAT, latest mode = ${mode}"
			if ((map.name == "heatingSetpoint" && mode == "heat") || (map.name == "coolingSetpoint" && mode == "cool")) {
				map2.value = map.value
				map2.unit = map.unit
		if (map2.value != null) {
			log.debug "THERMOSTAT, adding setpoint event: $map"
			result << createEvent(map2)
	} else if (map.name == "thermostatFanMode" && map.isStateChange) {
		state.lastTriedFanMode = map.value
	log.debug "Parse returned $result"
	result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd)
	def cmdScale = cmd.scale == 1 ? "F" : "C"
	def map = [:]
	map.value = convertTemperatureIfNeeded(cmd.scaledValue, cmdScale, cmd.precision)
	map.unit = getTemperatureScale()
	map.displayed = false
	switch (cmd.setpointType) {
		case 1:
			map.name = "heatingSetpoint"
			break;
		case 2:
			map.name = "coolingSetpoint"
			break;
		default:
			return [:]
	// So we can respond with same format
	state.size = cmd.size
	state.scale = cmd.scale
	state.precision = cmd.precision
	map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
	def map = [:]
	if (cmd.sensorType == 1) {
		map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? "F" : "C", cmd.precision)
		map.name = "temperature"
	} else if (cmd.sensorType == 5) {
		map.value = cmd.scaledSensorValue
		map.unit = "%"
		map.name = "humidity"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd)
	def map = [:]
	switch (cmd.operatingState) {
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_IDLE:
			map.value = "idle"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_HEATING:
			map.value = "heating"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_COOLING:
			map.value = "cooling"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_FAN_ONLY:
			map.value = "fan only"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_HEAT:
			map.value = "pending heat"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_COOL:
			map.value = "pending cool"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_VENT_ECONOMIZER:
			map.value = "vent economizer"
			break
	map.name = "thermostatOperatingState"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
	def map = [:]
	switch (cmd.mode) {
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_OFF:
			map.value = "off"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_HEAT:
			map.value = "heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUXILIARY_HEAT:
			map.value = "emergencyHeat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_COOL:
			map.value = "cool"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUTO:
			map.value = "auto"
			break
	map.name = "thermostatMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport cmd) {
	def map = [:]
	switch (cmd.fanMode) {
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_AUTO_LOW:
			map.value = "fanAuto"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_LOW:
			map.value = "fanOn"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_CIRCULATION:
			map.value = "fanCirculate"
			break
	map.name = "thermostatFanMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeSupportedReport cmd) {
	def supportedModes = ""
	if(cmd.off) { supportedModes += "off " }
	if(cmd.heat) { supportedModes += "heat " }
	if(cmd.auxiliaryemergencyHeat) { supportedModes += "emergencyHeat " }
	if(cmd.cool) { supportedModes += "cool " }
	if(cmd.auto) { supportedModes += "auto " }
	state.supportedModes = supportedModes
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeSupportedReport cmd) {
	def supportedFanModes = ""
	if(cmd.auto) { supportedFanModes += "fanAuto " }
	if(cmd.low) { supportedFanModes += "fanOn " }
	if(cmd.circulation) { supportedFanModes += "fanCirculate " }
	state.supportedFanModes = supportedFanModes
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	log.debug "Zwave event received: $cmd"
	log.warn "Unexpected zwave command $cmd"
// Command Implementations
def poll() {
	delayBetween([
		zwave.sensorMultilevelV3.sensorMultilevelGet().format(), // current temperature
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1).format(),
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 2).format(),
		zwave.thermostatModeV2.thermostatModeGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeGet().format(),
		zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format(),
        getBattery(), // CUSTOMIZATION
        setClock() // CUSTOMIZATION
	], 2300)
def quickSetHeat(degrees) {
	setHeatingSetpoint(degrees, 1000)
def setHeatingSetpoint(degrees, delay = 30000) {
	setHeatingSetpoint(degrees.toDouble(), delay)
def setHeatingSetpoint(Double degrees, Integer delay = 30000) {
	log.trace "setHeatingSetpoint($degrees, $delay)"
    sendEvent(name: "setHeatingSetPoint", value: "set heat temp to $degrees")
	def deviceScale = state.scale ?: 1
	def deviceScaleString = deviceScale == 2 ? "C" : "F"
    def locationScale = getTemperatureScale()
	def p = (state.precision == null) ? 1 : state.precision
    def convertedDegrees
    if (locationScale == "C" && deviceScaleString == "F") {
    	convertedDegrees = celsiusToFahrenheit(degrees)
    } else if (locationScale == "F" && deviceScaleString == "C") {
    	convertedDegrees = fahrenheitToCelsius(degrees)
    } else {
    	convertedDegrees = degrees
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: deviceScale, precision: p, scaledValue: convertedDegrees).format(),
	], delay)
def quickSetCool(degrees) {
	setCoolingSetpoint(degrees, 1000)
def setCoolingSetpoint(degrees, delay = 30000) {
	setCoolingSetpoint(degrees.toDouble(), delay)
def setCoolingSetpoint(Double degrees, Integer delay = 30000) {
    log.trace "setCoolingSetpoint($degrees, $delay)"
    sendEvent(name: "setCoolingSetPoint", value: "set cool temp to $degrees")
    } else {
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 2, scale: deviceScale, precision: p,  scaledValue: convertedDegrees).format(),
	], delay)
def configure() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSupportedGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeSupportedGet().format(),
		zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
	], 2300)
def modes() {
	["off", "heat", "cool", "auto", "emergencyHeat"]
def switchMode() {
	def currentMode = device.currentState("thermostatMode")?.value
	def lastTriedMode = state.lastTriedMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedModes")
	def modeOrder = modes()
	def next = { modeOrder[modeOrder.indexOf(it) + 1] ?: modeOrder[0] }
	def nextMode = next(lastTriedMode)
	if (supportedModes?.contains(currentMode)) {
		while (!supportedModes.contains(nextMode) && nextMode != "off") {
			nextMode = next(nextMode)
	state.lastTriedMode = nextMode
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[nextMode]).format(),
	], 1000)
def switchToMode(nextMode) {
	if(supportedModes && !supportedModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	if (nextMode in modes()) {
		"$nextMode"()
        sendEvent(name: "SwitchMode", value: "switched to $nextMode mode")
	} else {
		log.debug("no mode method '$nextMode'")
        sendEvent(name: "SwitchMode", value: "cannot switch to $nextMode mode, does not exist")
def switchFanMode() {
	def currentMode = device.currentState("thermostatFanMode")?.value
	def lastTriedMode = state.lastTriedFanMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedFanModes") ?: "fanAuto fanOn"
	def modeOrder = ["fanAuto", "fanCirculate", "fanOn"]
	while (!supportedModes?.contains(nextMode) && nextMode != "fanAuto") {
	switchToFanMode(nextMode)
def switchToFanMode(nextMode) {
	def supportedFanModes = getDataByName("supportedFanModes")
	if(supportedFanModes && !supportedFanModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	def returnCommand
	if (nextMode == "fanAuto") {
		returnCommand = fanAuto()
        sendEvent(name: "FanMode", value: "switching fan to auto")
	} else if (nextMode == "fanOn") {
		returnCommand = fanOn()
        sendEvent(name: "FanMode", value: "switching fan to on")
	} else if (nextMode == "fanCirculate") {
		returnCommand = fanCirculate()
        sendEvent(name: "FanMode", value: "switching fan to circulate")
	} else {
		log.debug("no fan mode '$nextMode'")
        sendEvent(name: "FanMode", value: "cannot switch fan to $nextMode mode, does not exist")
	if(returnCommand) state.lastTriedFanMode = nextMode
	returnCommand
def getDataByName(String name) {
	state[name] ?: device.getDataValue(name)
def getModeMap() { [
	"off": 0,
	"heat": 1,
	"cool": 2,
	"auto": 3,
	"emergency heat": 4
def setThermostatMode(String value) {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[value]).format(),
	], standardDelay)
def getFanModeMap() { [
	"auto": 0,
	"on": 1,
	"circulate": 6
def setThermostatFanMode(String value) {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: fanModeMap[value]).format(),
	], standardDelay)
def off() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
	], standardDelay)
def heat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
	], standardDelay)
def emergencyHeat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 4).format(),
	], standardDelay)
def cool() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 2).format(),
	], standardDelay)
def auto() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 3).format(),
	], standardDelay)
def fanOn() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 1).format(),
	], standardDelay)
def fanAuto() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 0).format(),
	], standardDelay)
def fanCirculate() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 6).format(),
	], standardDelay)
private getStandardDelay() {
	1000
// CUSTOMIZATIONS
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
    def nowTime = new Date().time
    state.lastBatteryGet = nowTime
    def map = [ name: "battery", unit: "%" ]
    if (cmd.batteryLevel == 0xFF || cmd.batteryLevel == 0) {
        map.value = 1
        map.descriptionText = "battery is low!"
        sendEvent(name: "BatteryLevel", value: "battery is low!")
    } else {
        map.value = cmd.batteryLevel
        sendEvent(name: "BatteryLevel", value: "battery is $cmd.batteryLevel%")
    map
private getBattery() {	//once every 24 hours
	def ageInMinutes = state.lastBatteryGet ? (nowTime - state.lastBatteryGet)/60000 : 1440
    log.debug "Battery report age: ${ageInMinutes} minutes"
    if (ageInMinutes >= 1440) {
        log.debug "Fetching fresh battery value"
		zwave.batteryV1.batteryGet().format()
    } else "delay 87"
private setClock() {	// once a day
	def ageInMinutes = state.lastClockSet ? (nowTime - state.lastClockSet)/60000 : 1440
    log.debug "Clock set age: ${ageInMinutes} minutes"
		state.lastClockSet = nowTime
        def nowCal = Calendar.getInstance(location.timeZone) // get current location timezone
		log.debug "Setting clock to ${nowCal.getTime().format("EEE MMM dd yyyy HH:mm:ss z", location.timeZone)}"
        sendEvent(name: "SetClock", value: "setting clock to ${nowCal.getTime().format("EEE MMM dd yyyy HH:mm:ss z", location.timeZone)}")
		zwave.clockV1.clockSet(hour: nowCal.get(Calendar.HOUR_OF_DAY), minute: nowCal.get(Calendar.MINUTE), weekday: nowCal.get(Calendar.DAY_OF_WEEK)).format()
    } else "delay 87"
def refresh() {
    // Force a refresh
    log.info "Requested a refresh"
    state.lastBatteryGet = (new Date().time) - (1440 * 60000)
    state.lastClockSet = (new Date().time) - (1440 * 60000)
    poll()
def coolLevelUp() {
    int nextLevel = device.currentValue("coolingSetpoint") + 1
    if( nextLevel > 99) {
    	nextLevel = 99
    log.debug "Setting cool set point up to: ${nextLevel}"
    quickSetCool(nextLevel)
def coolLevelDown() {
    int nextLevel = device.currentValue("coolingSetpoint") - 1
    if( nextLevel < 30) {
    	nextLevel = 30
    log.debug "Setting cool set point down to: ${nextLevel}"
def heatLevelUp() {
    int nextLevel = device.currentValue("heatingSetpoint") + 1
    	nextLevel = 99
    log.debug "Setting heat set point up to: ${nextLevel}"
    quickSetHeat(nextLevel)
def heatLevelDown() {
    int nextLevel = device.currentValue("heatingSetpoint") - 1
    	nextLevel = 30
    log.debug "Setting heat set point down to: ${nextLevel}"
Beats me - the only difference I noted was that you’re using decoration: “flat” and I’m not, but when I tried mine with that flag, it still works.
Have your tried perhaps deleting and reinstalled your device from scratch?
no I’ll give it a short (painful though).
Nest questions if it’s working without the Refresh capability/command - why change it? what benefit is there?
Yep then it worked. thanks
