I am wanting to get a Connect Home Pro and want to know if I can use the RBoy apps with it, specifically number 18 for Schlage alarm reporting and notification. TIA Dennis
The answer we have given to prospective ActionTiles customers, is that everything should work identically to those using a SmartThings Hub, as long as the āSmartThings Appā integration is used; rather than Samsung Connect App. Whether or not the two Apps can coexist is an area of some confusion. We have confirmation that ActionTiles works with Samsung Connect Home; I presume either by luck, or by following the preceding advice.
Another variable in the equation is whether to use a Samsung login or a SmartThings login, with the latter being less likely to have complications; especially for Samsung Accounts profiled as being in non-SmartThings overseas markets.
Yes it will, as @tgauchat pointed out it is compatible as internally they are running a SmartThings hub.
