Hi
I have a RPI3 that I programmed with Node-Red. I have it setup with a bunch of relays. I also have a number of temperature sensors connceted to it. Can someone suggest a method to connect this Pi to ST so I can control it from the ST Hub?
There is a tread on here regarding WebIOPI
I have seen some of those but I think webiopi isn’t available for the pi 3.
Yes it is. you just need to run a patch - https://github.com/doublebind/raspi
Got it. Will I be able to see temp sensors and gpio status? One thing is that I want to open/close garage doors.
