I don’t see any posts that are very recent and wondering if this still works. The installation instructions reference v1 hubs so I’m curious if this is still working/supported.
I just tried to install it on my first Pi, a brand-new 3+
I got this error:
BerryIO Installer
Updating repositories…
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Reading package lists… Done
Installing the prerequisites…
Building dependency tree
Reading state information… Done
Package php5 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package libapache2-mod-php5 is not available, but is referred to by another package.
E: Package ‘php5’ has no installation candidate
E: Package ‘libapache2-mod-php5’ has no installation candidate
Install failed!
I did some searching and PHP5 that module is not available for Stretch. There are some workarounds, but my advice would be to go back to Jessie and use that as you might solve this problem only to uncover another.
Who, or what, is Jessie? I’m brand new to Pi.
Jessie is the version of Raspbian before Stretch. You can still find it on the Raspberry Pi Foundations’s website. however, what are you looking to do with your Pi? Because I am using WebIOPi to control two GPIO pins as switches. It doesn’t work well for sensors but switches respond instantly.
I just wanted to be able to see/control it with ST. Nothing specific, just wanted to be able to link it. Is the WebIOPi option still available?
Take a look at OmniThing as another option for integrating a Raspberry Pi with SmartThings or Hubitat.
For what purpose though? just to see the status of your pi? there are a lot better ways to do that than through ST. If you are trying to control the GPIO pins then omnithing or webiopi are your best routes. If you’re trying to send commands to your pi, you can do that with omni thing. But you have to be more specific about what you’re trying to accomplish to get the best help.
Hello,
I have everythiing configiured, apache2, berryio, i can access that black/looking web via port 8082, everything is working from web…
from the the smartapp, also, if i reboot it will work, i would like to add a new Tile which I did to basically launch a command, that command is “sudo ps4-wakre” - but it won’t work, reboot will, but that new tile wont…
Here are some of my configs:
Blockquote
command “restart”
command “PS4ON”
command “PS4OFF”
main “button”
details([“button”, “temperature”, “cpuPercentage”, “memory” , “diskUsage”, “contact”, “restart”, “refresh”, “reboot”, “PS4ON”, “PS4OFF”])
def PS4ON(){
log.debug “PS4 ON”
sendEvent(name: “switch”, value: “off”)
def uri = “/api_command/ps4-waker”
postAction(uri)
def PS4OFF(){
log.debug “PS4 OFF”
def uri = “/apii_commnd/ps4-waker standby”
postAction(uri)
def reboot(){
log.debug “Restart was pressed”
def uri = “/api_command/reboot”
postAction(uri)
Does anyone know how to make this work>?
Hello,
Is OmniThing still live project ?
Is it working with the new Smartthings API ?
OmniThing is @leinax’s project. I am not aware of any recent efforts to make it work with the ST New API directly versus as a hub-connected LAN device. All hub-connected devices still use Groovy DTH’s, as ST has yet to announce any other option for hub-connected devices.
I’d like something like this that can accommodate maybe 12 temp input sensors (paired as input temp and output temp) on the Pi and displayed in ST app and able to perform automation on the temp values. Bonus to have local LCD display for each pair.
Any leads or ideas on how to do this?
