How often does the variable $randomLevel change?
It does not change per se. It’s a new random value every time you request it.
And how do I request it?
I am comparing the variable for a random light automation. So
If $randomLevel is less then 50 turn lights A.
If $randomLevel is greater or equal to 50 turn lights B.
Will that comparison cause a value change?
yes, each will get a new value. use:
if
$randomLevel is less than 50
then
turn on a
else
turn on b
end if;
or store the random value into a variable first and use the variable - though the if then else is the better, more efficient way
Thanks for the information!
With this will only one bulb be on at a time?
Thanks, one other question, if device is on at end of time restriction, how does it get switched off, I assume you dont want a light left on all night? Do you have another piston to switch everything off?
