With a regular light switch if I flip the switch OFF then I can not control the light with Smartthings software that is OK and I understand why, but if I use the Leviton DZMX1 and I turn OFF manually can I open the switch ON with Smartthings software or did I have to put back on like a regular switch to control back with Smartthings ?
The “off” on the Leviton is just an instruction to the device to cut the current to the fixture. The radio inside remains powered from the neutral wire and it will be able to hear the next “on” command from the network. This is true of all Z wave switches.
Thank you M. Roberts
