greg
(Greg)
January 4, 2017, 4:42pm
2
It isn’t actually automatic with GitHub integration either. However, it is much easier to tell when an update happens and what the changes were. Then you can manually select to update your app with a few clicks
Try this FAQ
I couldn’t find a good/in-depth FAQ for a GitHub How to with ST so here goes:
If you’re looking for uk integration:
Please, I am by no means an Expert, If you find an error or see something that I should change let me know and I will update it.
Log into the IDE @ https://account.smartthings.com
Enable and Link your GitHub Account: Section taken from Smartthings developer docs
Step 1 - Enable GitHub Integration
Click the Enable GitHub Integration link on the My SmartApps or My Device >Types page. This will launch a wizard that will guide you through the process.
[image]
Step 2 - Connect your GitHub Account to SmartThings
On Step 1 of the wizard, follow the instructions to authorize SmartThings to integrate >with your GitHub account. Click the Next button after you have done t…
