Could be you’re missing one mode change and then you run into the following problems: (this is a clickable link)
Basically just have to walk through your Mode changes and make sure you never trying to run routine when you’re already in that mode.
So first thing in the morning what mode is your house in? Maybe home?
You leave the house, what changes it to away?
Your wife comes home at lunch, if the house was in Away, does it change back to home again when she arrives? If not, and it still away, then the next goodbye routine will not run if it is also supposed to change it to away.
This might not have anything to do with what you’re seeing, but it’s a very common issue so it’s worth looking at.
