I have had horrible luck with getting my Nest to
function as i would expect. I can get it to connect in ST, i Can see it
and i can control it from the things menu. However if i set an event to
fire the Nest to say 74Deg at 9 pm then it just doesn’t do it. It show
it has in the activity monitor that it did, but doesn’t actually do it.
And when i go look at the nest in the Things view it still shows it is
set at what it was set at before the event. Also the thermostat and the
things view seem to be in sync, most of the time.
I’m having the same problem. Nest can be controlled directly as a Thing but not controlled in a Routine. Help!
