I have a problem with this driver. It paired well with the hub but the sensor changes from open to closed after 5 seconds of being open although it is still open. I tried with a new sensor but have the same problem. For some reason the driver defaults back to closed.
The driver does not emit the closed event if the device does not send that command to it.
Therefore check the manual of your device in case it has any configuration parameter that controls the reset time of the open state
There are no configuration parameters for the device. It worked 100% with the DTH for years. I still suspect something with the driver. It might be that the driver re-initializes for some reason. Is there a way to check all of this in the logs?
This version of the driver already has the subdriver for the Heiman HS1DS-Z Contact Sensor to work correctly.
In 12 hours maximum it will be updated on your hub and you will be able to change to this driver again, then I will delete the TEST driver version of the channel. You can use the TEST version as long as you don’t delete it from your Hub
Name Z-Wave Sensor and Child Thermostat Mc
Version 2023-03-31T22:19:14.973316174
This driver version has the tamper Alert modifications
Will be updated in the next 12 hours or installed with CLI
Version 2023-04-01T21:02:32.550344307
