I recently bought my first SmartThings hub (v2) in a kit with two lightify a19 bulbs. So far everything is working great and i can control the lights from the app or my Google Home. However I also wanted to try integrating with IFTTT --but every time i try to connect from ifttt it fails.
I’m going to https://ifttt.com/smartthings where I click connect, enter my ST credentials and then get a screen where I select my location and get a list of devices. I check my bulbs under switches and click authorize. And I get message on the next screen that says “Could not connect SmartThings” and ifttt doesn’t let me use SmartThings in recipes – it acts as if I’ve never logged in. I can see IFTTT under Smartapps now in the app on my phone too, but again IFTTT acts as if it can’t see anything.
Same problem here. Thought that IFTTT and Google Home might be fighting over “automation rights” because I can voice control the lights w/o IFTTT (which I didn’t expect to be able to do). But I would rather use IFTTT b/c it is much more flexible. I also have a harmony hub which has connected to IFTTT and Google Home without issue. Hope the context helps!
I don’t get any notification. after I authorize it goes back to the recipe in the off position. i click it on and i go through the whole routine again. It does show up in the smartthings app (it is a door lock) though. I am trying to get the door to lock through alexa.
Thanks for making the gif – it makes it easy to confirm that our experiences match exactly.
An additional data point… when I go back to my SmartThings iOS app, it clearly shows a connection to IFTTT, and I get the familiar, granular permissions page.
However, upon going back to IFTTT to use the SmartThings device, it says I am not connected, and we’re back to your gif.
I have the same problem as well. New to ST and IFTTT connectivity was one of the main reasons to get ST. I also have (2) 8 series TV and they can’t connect to ST either. That’s (2) strikes against ST for me. Hoping it is an easy fix for ST dev. It seems like IFTTT is setup to use the OLD api endpoints for Hub v1?
