Anyone else have problems with trigger to turn on light in one room is also triggering to open garage or other action it’s not connected to???
Look at the garage and light device, go to smartapps section for each device under things. Check to assure that each assigned smartapp is doing what you expect. I suspect that you have accidentally tied the light to opening the garage somehow.
Thank you I will check my apps and see if I can find anything
