I have a question about the usage of Smarthings with a Fibaro device that we want to use to control a roller shutter.
I have the smartthings hub V2 and a Fibaro FGS-222 relay switch.
Starting from completely closed shutter we want the switch to turn on and then turn off after 1800 milliseconds so that the shutter stops in the half open position.
When we first programmed the task with the rule machine plugin two years ago it worked but then after a SmartThings update the routine stopped working.
Now it seems like the second signal after 1800 milliseconds is not received correctly and therefore the roller shutter keeps opening without stopping in the desired position.
Can you help us and let us know how we can realise our desired routine?
Thank you Robin! Actually I was wrong, I do not need to switch OFF after 1800 ms but instead I need to click ON again to stop the roller shutter. Basically I need to switch ON to start the roller shutter movement and then ON again after 1800 ms to stop it in the position I want.
Unfortunately that is how the roller shutter works, in order to stop the movement you need to push the same button again that you used to start the movement.
Actually it is not ON and ON again but it is UP and then UP again… I configured the fibaro switch in a way that ON is UP and OFF is DOWN. That means I need to turn it ON and then ON again after 1800 ms (UP and then UP again)…
Also I just checked again and actually the fibaro switch that I am using here is not the FGS-222 but instead I am using the FGRM222 Roller Shutter Switch…
I hope it makes sense
Would be awesome if you could help me here to figure this out. Thanks so much!!
Hi, yeah sorry with all the stuff that I have set up with Fibaro devices I mixed up things…
I have the fibaro roller shutter device outputs Q1 and Q2 directly going into the bus that controls all the shutters in my house (and the original switches do not go into the S1, S2 and L inputs). So if the fibaro sends a down signal then all my roller shutters get a down signal on the bus and go down and if it sends an up signal they all go up.
So if I use the FGRM 222 code flying around the community (Fibaro FGRM 222 - Roller Shutter) then the UP and DOWN features work great but my problem is that I want to turn all the roller shutters up (starting from completely closed) and then stop the movement automatically after approx. 1800 milliseconds so that the shutters stop in a half open position (so that some light comes in but they are not open)…
If I set up a routine for that in rule machine or CORE it seems like the fibaro device does not get the second signal or maybe misses it since it is too fast? (1800 ms after the first UP I am clicking UP again).
Any recommendations on how to have a reliable setup where every time when I run a routine it does the required use case (start the UP movement of the shutters and then stop it again 1800 ms after)? I would also be willing to buy another fibaro or other z-wave device if you think that would help.
Yes, it does stop when I press the button again in the ST app but only after a certain amount of time, if I press it and then press again right after it does not recognize the command. Only if I wait maybe 2-3 seconds it works…
I also believe the only option to have this work reliably is to calibrate the device and then use the slider.
The problem is that I think calibration only works if the device is connected directly to a motor that sends a signal back to the fibaro device once it arrived all the way up/down.
In my case the fibaro device is connected to a bus and on the bus I have all the roller shutters of the house… that means that the device does not get a signal back once the motors arrived all the way up/down and therefore I am not able to calibrate the slider…
Any ideas on how I can manually calibrate the slider and define the min and max values for the slider so that it knows where all the way up/down are?
It worked to run the piston with the test (22,18,2) command but then when I have the roller shutter run it does not stop after 18 seconds… how can I test if it worked to set the parameters?
