Hello,
i am running Linux KNX 5.10.0-19-amd64 #1 SMP Debian 5.10.149-2 (2022-10-21) x86_64 GNU/Linux
and i have problems running smartthings commands as cron jobs.
Here is how my crontab looks
33 * * * * sudo /usr/bin/smartthings devices:commands XXXXXXXX-XXXXX-79b2-4577-00000XXXXXXXX main:switch:off
I try everything to debug that problem reading logs etc. no output from that job is generated just the command won’t run.
Anyone met this problem ?
AlejandroPadilla
(Please contact @nayelyz or @Luis_Humberto_Medina )
2
I don’t really familiar with crontab, but if you don’t receive logs or something like that maybe the sudo is waiting for the password.
All other cron jobs with sudo works … only smartthings doesn’t work.
If i run directly from the console it works.
If i put smartthings inside bash script all the commands work till the line with smartthings…
It’s been a long time since I did this sort of thing. Back then I would have redirected stdout to a private logfile and then redirected stderr to stdout so I got the logging of the CLI where I wanted it, not where cron may or may not have been configured to send it.
I’ve not used the CLI with sudo. Does that not have implications for the configuration or have you already allowed for that?
