I searched and can’t seem to find the thread.
In the Classic App we had the capability to see which User was HOME or AWAY
The NEW app doesn’t give that option anymore
I thought I read somewhere someone did a work-around to where you had a Tab in the New App where you could see USER Status PRESENT or AWAY
Can someone direct me where I can find that thread again?
Since Classic App is RIP…I would like this option again in the New App
Thankyou in advance
One way to do is to:
Create a virtual switch for each user
Create a room for these user switches
Move the “User” room to the top of the Home Screen
Create automations to turn the virtual switches on/off based on each user’s location
The users that are home will have a colored switch tile, those who are away will have a greyed out switch tile.
Derakkon THANKYOU…
i think this was what I was looking for.
Is there a possible way you can email me or reply here a step by step instructions on how to do this?
Please Confirm …this virtual switch Does Work ?
I’ve been a ST user since 2013…I only have about 15 Zwave devices…
I’ve never dived in to the IDE or Webcore…so I’m still a newbie…lol
Thankyou in advance
To create a virtual switch in the IDE:
Sign into https://account.smartthings.com/
Click the My Devices tab at the top
Click the + New Device button
Enter the device name and copy it to label
Enter a unique Device Network ID (This can be anything, but I don’t think it can include spaces)
Under Type, scroll down and select Virtual Switch
Select your location and Hub under those dropdown menus
Then click create
Now your device should show up in the app
Repeat from step 3 for each user device you want to create
In the SmartThings app:
Tap the + icon and select Room
Scroll down to the bottom and select Custom
Enter the room name (such as Users)
Tap Next, Select a Wallpaper, and then tap Save
Tap the < to back out of the room to the Home Screen
Scroll down to the bottom to the group “No room assigned”
Tap move to other room
For each user device, select your Users room from the dropdown next to each device
Tap Save
Your User devices should now be at the top of the Home Screen
Now to set up the automations:
Tap the + Icon and Automation
Under If tap the + and select Member Location
Select the User under Who?
Under When? select This member is at Home and tap Save
Under Then tap the + and select Control devices
Scroll down and select the user switch corresponding to the user selected above
Tap Next, On, Save, and Save
Name the automation and tap OK
Tap the + icon again
Select the same User as before under Who?
Under When? select This member isn’t at Home and tap Save
Tap Next, Off, Save, and Save
Repeat for each User
thankyou!
I will have to tackle this tomorrow morning
STbc
October 25, 2020, 7:54am
#6
Thank You from those of us that are IDE challenged.
Bry
(Bryan)
October 25, 2020, 2:17pm
#7
To see the location mode: 3 dot menu, Manage Location
I’m on it this morning…
let’s see if I"m successful
FINISHED
Derakkon thankyou soo much
*this is where I praise the community forum and where Samsung Support fails…
rtorch
(Ralph Torchia)
October 25, 2020, 8:09pm
#9
I created a virtual presence sensor, so that it looks nicer than using a virtual switch. It will display Present or Not Present, and is used with automatons.
Novicetwo
(Doug. When will mobile presence work?)
October 25, 2020, 10:52pm
#10
Thank you Derakkon. Appreciate your time with the very helpful tutorial.
