@Aaron
Zigbee Presence Sensors Work By Checking In every Minute or So
A presence sensor which was always âawayâ or one which kept bouncing between being âawayâ and âpresentâ could easily represent any of the issues you describe with range, interference, or an incomplete pairing.
And if presence is based on GPS, as with a mobile phone, reporting can come from the wrong location sometimes.
However, a zigbee presence sensor which is always reported as âpresentâ is something else again. That would typically represent a failure on the cloud side, not the device. Itâs not based on âwhere I saw you lastâ reporting as GPS is. Itâs a direct connection to the ST Hub at the home.
A zigbee connection can be lost due to interference, just as turning on the microwave might cause Netflix to buffer. But it canât be falsely maintained through any of the factors you listed. The arrival sensor doesnât check out when it leaves. Instead, the cloud account notes repeated failures to check in locally as the sign that the device is âaway.â
Thereâs No âCheck Outâ Signal to be Lost in the First Place
So either the hub isnât passing along the check-in information to the cloud or the cloud isnât recording/processing it correctly, but honestly I donât see how the sensor itself could contribute to a sustained false positive. Sustained false negative, sureâif the sensor canât maintain enough power to check in regularly, it eventually gets marked as âawayâ when itâs really home.
"Teleportationâ between âawayâ and âhome,â sureâthe device isnât checking in properly or thereâs interference.
But sustained false positive for hours or days? Thereâs nothing the Zigbee sensor itself can do to cause that. (A GPS based device can, but not the Zigbee device.)
Resetting the battery in this cases is likely forcing the cloud account to resynch as well.
If Itâs Really a Sustained False Positive on the Zigbee Presence Sensor, Thatâs Very Odd
Make sure the engineers know that whatâs being reported in this thread is nothing to do with GPS devices or bounce or false away statuses.
Itâs a zigbee presence sensor being falsely reported as present for hours at a time. And multiple people reporting that things were OK and then the error started happening. And some reports of two in one home failing at the same time.
This just doesnât fit âthe usual suspectsâ for a presence detection error. If these were mobile phones, sureâGPS-based devices can do that. But the Zigbee device just doesnât have a local protocol that should fail in that particular way. It really sounds like something else is going on.
Submitted with respect.
