You might try unpairing+pairing that device then. Z-wave reporting has to do with the device’s firmware, not anything to do with the device type. Try removing it, powering the device off for a minute, and then rejoining. If that doesn’t fix you up, you might want to start a new thread asking for help. I don’t think that’s typical of these devices.
I’m seeing some confusion here.
I think what you’re talking about is that after it detects motion it is one minute until it will report detected motion again.
So if it’s controlling a light and the light goes off after 30 seconds it takes another 30 seconds before it will turn it back on.
That’s what my Ecolink sensors doo, and they are the same as the monoprice just a different name.
When he days seconds, he means that it reports within seconds of detections. But it still has a timeout if at least a minute.
Sorry for the off-topic post. I moved this conversation to here…
Before we do, I have two of the EcoLink version of this PIR sensor, I’ve just left it permanently in test mode so it’s constantly and instantly reporting motion/no motion, they’ve been this way for nearly a year now, one is reporting 99% battery, the other is reporting 100% battery, which even if they are wrong, they’ve still been configured in test mode for nearly a year so…
Y’all really need to take this to another thread. Troubleshooting is not what his thread is for.
It already did, we’re now just compounding the problem
Phillips Hue Bloom is back in stock for $59.97 at Home Depot - http://www.homedepot.com/p/Philips-Friends-of-Hue-40W-Equivalent-Adjustable-Color-Connected-LED-Bloom-Lamp-White-Single-259515/205316161
" Back in stock " is relative. I already bought out the stock at my local HDs
- They have five of each kit left. 33542
Do you need the Hue hub to connect this to ST, or can this be connected directly as an object?
Great find! I picked up 4 nest cams
these work with ST properly?
I just ordered all 8 my store shows in stock I guess Ill find out woot
Just curious…what is this in reference too?
Yes, those switches work great with ST.
I’ve got around 45ish of them installed
http://www.lowes.com/ProductDisplay?productId=3707736
Its a basic on/off Iris switch. On clearance for $8.75 each with 10% more off if you order 4 or more so 8 in wall switches for $68.14 with tax!!!
Showing $35 for me right now, which is too bad.
yeah they just called me from the store. They canceled my order said its a non stock item and the system was wrong
If anybody is still in the market for a new Harmony Ultimate Home, $199 BB daily deal
http://www.bestbuy.com/site/logitech-harmony-ultimate-home-black/8203175.p?id=1219317044078&skuId=8203175
$5.98
SYLVANIA ULTRA 11-Watt (65W Equivalent) 2700K BR30 Medium Base (E-26) Soft White Dimmable Indoor LED Flood Light Bulb ENERGY STAR
360 View
Store #0517 Charlottesville Va 22911
http://www.lowes.com/pd_673725-3-79166_0__?productId=50373460&Ntt=
Update Not available for mail order sorry,
This is at the Charlottesville Va 22911 Store #0517; you can mail order. Just set that lowe’s as your store. I’ve done it with others to get deals. Don’t forget to use the coupon generator.
Maybe it would be a good idea if we started posting store numbers for HD and Lowe’s
