This is so cool! Thank you so much for the direction. I am using an Aeon Labs HEM V1 with your code and it tracks the power usage just fine. I am also trending temperature inside and outside with this and matching it up with the power usage to better understand my cost and control energy footprint in the future.
Here is my modified app, if it will help someone. I take no credit. I just moved things around is all.
* GroveStreams
* Copyright 2014 Jason Steele
definition(
namespace: "JasonBSteele",
author: "Jason Steele",
description: "Log to GroveStreams",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Log devices...") {
input "temperatures", "capability.temperatureMeasurement", title: "Temperatures", required:false, multiple: true
input "contacts", "capability.contactSensor", title: "Doors open/close", required: false, multiple: true
input "accelerations", "capability.accelerationSensor", title: "Accelerations", required: false, multiple: true
input "motions", "capability.motionSensor", title: "Motions", required: false, multiple: true
input "presence", "capability.presenceSensor", title: "Presence", required: false, multiple: true
input "switches", "capability.switch", title: "Switches", required: false, multiple: true
input "powers", "capability.powerMeter", title: "Power Meters", required:false, multiple: true
input "energys", "capability.energyMeter", title: "Energy Meters", required:false, multiple: true
section ("GroveStreams Feed PUT API key...") {
input "channelKey", "text", title: "API key"
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
subscribe(temperatures, "temperature", handleTemperatureEvent)
subscribe(contacts, "contact", handleContactEvent)
subscribe(accelerations, "acceleration", handleAccelerationEvent)
subscribe(motions, "motion", handleMotionEvent)
subscribe(presence, "presence", handlePresenceEvent)
subscribe(switches, "switch", handleSwitchEvent)
subscribe(powers, "power", handlePowerEvent)
subscribe(energys, "energy", handleEnergyEvent)
def handlePowerEvent(evt) {
sendValue(evt) { it.toString() }
def handleEnergyEvent(evt) {
def handleTemperatureEvent(evt) {
def handleContactEvent(evt) {
sendValue(evt) { it == "open" ? "true" : "false" }
def handleAccelerationEvent(evt) {
sendValue(evt) { it == "active" ? "true" : "false" }
def handleMotionEvent(evt) {
def handlePresenceEvent(evt) {
sendValue(evt) { it == "present" ? "true" : "false" }
def handleSwitchEvent(evt) {
sendValue(evt) { it == "on" ? "true" : "false" }
private sendValue(evt, Closure convert) {
def compId = URLEncoder.encode(evt.displayName.trim())
def streamId = evt.name
def value = convert(evt.value)
log.debug "Logging to GroveStreams ${compId}, ${streamId} = ${value}"
def url = "https://grovestreams.com/api/feed?api_key=${channelKey}&compId=${compId}&${streamId}=${value}"
def putParams = [
uri: url,
body: []
httpPut(putParams) {
response ->
if (response.status != 200 ) {
log.debug "GroveStreams logging failed, status = ${response.status}"
