Post Requests for Zwave Edge Drivers Here (community-created)
I think they are included in the stock driver.
Hi
I have got another Qubino relay, any chance you can add this fingerprint to
Z-Wave Switch Mc
when you get a minute.
I will give this a look, thanks!
Hi @uncledaveghr
This device is in stock smartthings driver.
It will be migrated automatically, if you wants install now is in my zigbee switch Mc and stock beta zigbee switch drivers
#   - id: 0159/0002/0051
#     deviceLabel: Qubino Switch
#     manufacturerId: 0x0159
#     productType: 0x0002
#     productId: 0x0051
#     deviceProfileName: qubino-flush2-relay
Working on them this weekend. Should have something to beta test next week!
Hi
Qubino relay is z-wave device
Cheers Dave
Im also looking for the Homeseer FLS1000+ I use this sensor to trigger all my outside lights.
My info is the same: (zw:L type:0701 mfr:000C prod:0201 model:000B ver:1.04 zwv:5.03 lib:03 cc:5E,85,59,55,86,72,5A,73,9F,6C,7A,71,25,31,70,30), I am using the DTH from HomeSeer.
Just as @philh30 says, only range extender cabability, but somehow I will hope we would be able to see route for a device in a webpage like interface as it is in groovy IDE, then you will be able to see if your extender works.
Of course, Los but so do I. The other day I said that I don’t think it works, because I put an extender next to another device but it continues to disconnect
Did you run a zwave repair after you moved the extender? The other device might take a few days to change its preferred route unless you do. :thinking:
No, also because I only have two zwave devices and the extender is zigbee
Would love a driver for the ZFM-80. Had a DH working for couple years using it to control fireplace as relay. With recent updates smartthings shows the device as “online” but cannot control the switch anymore.
I second the request for a driver for the ZFM-80. For years I have been using this device to control my garage door and it has worked flawlessly. I would hate to lose this function.
Need a driver for Qubino flush 2 relay device. Thanks,
Also need a driver for Intermatic CA 3750. Currently I am just using a generic z-wave switch driver which works fine but I won’t be able to assign this when the IDE goes away. Thanks!
Are there edge drivers for:
MyQlite & Ecolink zwave tilt sensor?
Ecolink Z-wave Plus Rare Earth Magnets Door & Window Sensor (I use this to make a dumb doorbell alert ST).
He is attempting a replacement for MyQ.
MyQ thread but now ETA yet.
Ecolink zwave tilt sensor is in the stock Z-wave sensor driver and works well.
As for the Ecolink Z-wave Plus Rare Earth Magnets Door & Window Sensor you would have to look in the github and see if the fingerprint is included.
I installed the driver then did a “scan nearby” and they all showed up. Unfortunately though, they all just say Connected. I’m not able to control the devices or see the state.
I’m not sure if I need to disable the LIFX<>Smartthings cloud integration first though.
Yes I would disable the cloud integration, though that should not prevent the edge driver from working correctly. Which LIFX devices are you using?
