3 posts were split to a new topic: Writing an HSM200 edge driver
A post was split to a new topic: Tuya Smart Life ZigBee Energy Meter 80A with Current Transformer Clamp
@RafaelAntonio2022 you keep asking Mariano to add these Tuya devices and I think he’s explained why they don’t work with Mc drivers. Someone else is doing Tuya devices, please search the community.
@RafaelAntonio2022 Sure, if you put “tuya soil sensor” into the search feature of the ST community forum, it will give you 6 results, the first result has the Edge driver. My advice first before buying a sensor, especially from China, is to search user reports of the sensor in question, unless it’s a new sensor and you want to experiment. I bought 2 of these soil sensors, I can tell you they are not accurate or reliable, and they spam your Zigbee network by sending reports every 5/10 seconds. I am not using them.
A post was merged into an existing topic: (EDGE Driver-Mc): Z-Wave Edge Drivers and others with FIBARO devices:
Hi
I have got another Qubino relay, any chance you can add this fingerprint to
Z-Wave Switch Mc
when you get a minute.
I will give this a look, thanks!
This device is in stock smartthings driver.
It will be migrated automatically, if you wants install now is in my zigbee switch Mc and stock beta zigbee switch drivers
# - id: 0159/0002/0051
# deviceLabel: Qubino Switch
# manufacturerId: 0x0159
# productType: 0x0002
# productId: 0x0051
# deviceProfileName: qubino-flush2-relay
Homeseer leak sensor LS100+ Water Sensor edge drivers?
Working on them this weekend. Should have something to beta test next week!
Hi
Qubino relay is z-wave device
Cheers Dave
Im also looking for the Homeseer FLS1000+ I use this sensor to trigger all my outside lights.
My info is the same: (zw:L type:0701 mfr:000C prod:0201 model:000B ver:1.04 zwv:5.03 lib:03 cc:5E,85,59,55,86,72,5A,73,9F,6C,7A,71,25,31,70,30), I am using the DTH from HomeSeer.
Just as @philh30 says, only range extender cabability, but somehow I will hope we would be able to see route for a device in a webpage like interface as it is in groovy IDE, then you will be able to see if your extender works.
