Post Requests for Zigbee Edge Drivers Here (community-created)
Thank you!
hello guys, I bought a zigbee water valve, but it keep in closing every 10 minutes, is there a possible to cancel this? Here are the device details.
Good afternoon, need some help to add a device to my smartthings hub. Don’t finde a driver that works properly with it.
Zigbee switch with temperature sensor.
I manage to add it to smartthings but don’t get a temperature reading.
I have read in github they manage to get it working in zigbee2mqtt
Thanks for your help
Should work with wonjj6768 - SmartThings Zigbee Edge Drivers
Try to install his drivers from here:
Hi thanks for your help, I had already check the drivers that you recomended but haven’t seen any that inthe description would work. Any in particular?
Try this one : EF00 Switch wonjj6768
Hi, I have tried that. The switch works but doesn’t read temperature.
Hi @Haitham_Khasawneh, I do have the same problem here with my Sonoff SWV-ZFE.
@Andreas_Roedl might you know the answer? Please see the logs attached. I have installed your driver. I also increased the manual water duration to 240 minutes, but this has not solved the problem. I would be really helpful because I know have to open the valve every 10 minutes manually.
UPDATE: I can see there is already a conversation running at: [ST Edge] SONOFF Hydro ONE / DUO family (SWV-ZFE / SWV-ZFU / SWV-ZNE / SWV-ZNU / SWV-ZF2E / SWV-ZF2U) - Devices & Integrations / Community Created Drivers - SmartThings Community
@Haitham_Khasawneh please check it there if that solves your problem. I am going to read and test it there.
Hi @Leetjevw , the problem that my valve is not Sonoff, the driver didn’t appear.
For now, i did a workaround to override the 10-minutes shutoff, its by creating two routines as per below, (attached are the screenshots):
  1. If the location mode is Home, and valve get closed, then open
  2. If valve is open for 10 minutes, then open
Its not the perfect solution, especially that the valve will close briefly then open, but in my case, I didn’t feel a water supply cut in my home appliances…Hopefully to find a solution soon, or at least a model which doesn’t have this auto shutoff!
Fir
Firmware issue.
@Mariano_Colmenarejo
This is a zigbee single button from aliexpress, here is the info that shows using your thing mc driver. Could you please add this, i did not find it anywhere yet by searching, thank you:)
. Manufacturer: HOBEIAN
· Model: ZG-101ZL
. Endpoint: 0x01
· Server clusters: 0000, 0001, 0003,
0004, 0006, E001, 1000
. Client clusters: 0003, 0004, 0006,
0008, 000A, 0019, 1000
. Symptoms: Pairs successfully with
Zigbee Thing Mc, but no battery
reports and no button events.
Try one of @wonjj6768 drivers from SmartThings. Add a little smartness to your things.
ok i will, thank you
all the drivers say EF00, isnt this button different?
Except for those who start with ZCL.
You can access @wonjj6768 github and read through the list of supported fingerprints.
You can also open an issue if the device isn’t supported.
found it, thank you, im not sure why it did not show up in a search, it did locate the line with browser FIND. Thank you for pointing me in the right direction.
Device Driver Request: Schneider Electric Wiser 4-Button Wireless Switch (WDE002924)
  • Device Name: Schneider Electric Wiser 4-Button Wireless Switch (Exxact / System M / LK FUGA series) (WDE002924)
  • Manufacturer Code: Schneider Electric
  • Device Model: FLS/SYSTEM-M/4
  • Type: ZIGBEE
Description: This is a battery-powered 4-button wireless switch/remote. It currently pairs as a generic “Zigbee Thing” with no exposed button capabilities or press events. If possible, it would be great to have single press, long press and double press supported.
Could this fingerprint be added to one of the community Zigbee button Edge drivers? Please let me know if you need any additional cluster or endpoint details!
You realize that this is quite a complex device? Adding a fingerprint is not enough.
Anyway…
  • Delete the device in SmartThings.
  • Install the Schneider Wiser 4-Button Wireless Switch driver from this channel.
  • Add the device to SmartThings.
  • See what happens - it’s a very first alpha version, loosely based on this driver.
Thanks a lot for the fast reply and development!
I tested it
  • Installed nicely with the Edge driver.
  • All buttons are shown as “standby”, button presses on the device will not trigger actions setup for the button. Neither are the button presses recorded in the history tab
Anything I can help with, do you need any data?
