Post Requests for Zigbee Edge Drivers Here (community-created)
Please add finger prints for the Sonoff S40 Lite Zigbee Plug. It’s currently listed as DTH and there is no DTH on my account.
“deviceManufacturerCode”: “SONOFF”,
“manufacturerName”: “SmartThings”,
“deviceModel”: “S40LITE”,
“presentationId”: “SmartThings-smartthings-ZigBee_Switch”,
Raw Description: 01 0104 0009 01 07 0000 0003 0004 0005 0006 FC57 FCA0 01 0019
Hi everyone, does someone know or can create an edge driver for linkind motion sensor and contact sensors? i only found the driver for the leak sensor
I have the heiman smoke sensors working on this one
Hope this helps
Or maybe you could use a virtual device set as fire alarm
Thanks. Using a virtual device was one option, but my preference was to add the Ecolink fingerprint to a z-wave smoke alarm driver if someone was customizing one.
909 posts were merged into an existing topic: Post Requests for Zwave Edge Drivers Here (community-created)
Hi @Mariano_Colmenarejo
Added fingerprint works for Vendor _TZ3210_sroezl0s
Color temperature seems fixed at 4000 K as stated in specs (slider have no effect)
Color control works
(Color Changing) mode, when ON works
Thakyou again
Hi @rubberduck72
Changed to level-rgb profile in this driver version
│ Name        │ Zigbee Light Multifunction Mc        │
│ Version     │ 2022-09-01T18:26:11.505815301        │
  - id: "_TZ3210_sroezl0s/LIDL"
    deviceLabel: LIDL TS0504B
    manufacturer: _TZ3210_sroezl0s
    model: TS0504B
    deviceProfileName: level-rgb
Could you please provide a summary/guide on how to actually install your linked edge drivers onto my hub?
@BarryA AMAZING! I have been waiting for this. Thank you so much for your work. Does this allow control of multiple bulbs as a group? Do you have a channel invite link or how do I go about installing this?
Any updates on the Homeseer leak sensor
LS100+ Water Sensor edge drivers?
The driver in the beta channel for ST edge worked for me. It doesn’t support temperature reporting though.
Got a couple of these IKEA zibee repeater
Maybe someone could look into add this
Thankyou
Seems so, I’ll then waite for great transition
Thankyou
How can you create a driver for this Ikea shortcut button?
Hi @Helder_Rodrigues
Other users have already asked for the same thing.
I don’t know how to make that driver for this device, sorry
Thank you, I figured it would be more complicated than I was assuming.
I use the Zigbee Range Extender of the beta channel from samsung. It recognized the extender, but I have no way of knowing if it actually works well or not.
Channel and Drivers Web UI
Did you ask it because you didn’t know it was there or because you already know it doesn’t work well and you would like a specific one?
The ones I have is on the stock “Zigbee Range Extender” DTH and they do the job as expected. Yes I didn’t know of the fingerprint already was added to the new stock edge driver, so I believe they will work as well after the transistion and I’m not part of beta program, so I have not tried any of the stock beta edge drivers
EDGE beta drives are available to everyone, just allow access to the hub and then select the desired drive, delete the extender in dh and search for it again, it will be inserted in edge. Try it, so you can tell me if it works.
