Post Requests for Zigbee Edge Drivers Here (community-created)
Hi @Haitham_Khasawneh, I do have the same problem here with my Sonoff SWV-ZFE.
@Andreas_Roedl might you know the answer? Please see the logs attached. I have installed your driver. I also increased the manual water duration to 240 minutes, but this has not solved the problem. I would be really helpful because I know have to open the valve every 10 minutes manually.
UPDATE: I can see there is already a conversation running at: [ST Edge] SONOFF Hydro ONE / DUO family (SWV-ZFE / SWV-ZFU / SWV-ZNE / SWV-ZNU / SWV-ZF2E / SWV-ZF2U) - Devices & Integrations / Community Created Drivers - SmartThings Community
@Haitham_Khasawneh please check it there if that solves your problem. I am going to read and test it there.
