Post Requests for LAN Edge Drivers Here (community-created)
Does anybody still use a Samsung R3 multi room speaker?
I use mine for announcements, but I’m wondering if it will still work with an edge driver. Currently it is still using groovy I guess.
I have a few Samsung Multiroom speakers which I’ve been using for notifications, this is currently working on IDE using LAN Samsung Audio. A few days ago all my speakers doubled up and appeared in No Room Assigned with a SamsungAudio Edge driver which was added through the SmartThings Drivers (Beta) channel. I have tried using these doubled up “Edge” speakers for notifications but they do not seem to work, I may need to delete the old “IDE” speakers for this to work but I’d rather wait and try that when i am forced to.
Several people requested an edge driver for Awair air quality sensors. Here’s one:
@mvevitsis
@Derek.Holt
Hi - sorry for not responding earlier, but just seeing your post regarding Ambient Weather. If there is still interest in this, I could look at adding support for this source to my Edge weather driver.
It does however require that you run a bridge app on an always-on LAN computer, so that the driver can get to the internet.
Is there a simple edge driver somewhere that supports http(s) temperature readings with frequent updates?
If not, can someone create one?
I think this is a very frequent solution desired for different use-cases with home-made equipment. It would be even better if it could support rain and other values as well.
Marianos drivers for HTTP integration can read values, but I haven’t found a solution that allows me to create a thermometer out of that (not even a virtual that I feed the values to). That would be an alternative if possible, but that driver is a bit limited as well as it requires JSON for the thermometer.
Any ideas of alternatives, that does not include becoming a developer?
The question above is a generalization of what I really am planning to do and that is to interact with Domoticz. But temperature is my major pain-point today.
Maybe @TAustin HTTP Devices driver is solution for your use case
HTTPDevices/README.md at main · toddaustin07/HTTPDevices · GitHub
It looks interesting, but it is clearly stated that it is only sending requests, not capable of receiving data.
I will definitely test what it is good for though.
Take a look at the “edge services“ quick browse list in the community-created wiki. Several people have created projects which are capable of sending and receiving.
https://thingsthataresmart.wiki/index.php?title=Quick_Browse_Lists_for_Edge_Drivers
After that, if you don’t find an existing project which meets your needs, I suggest you start your own thread under projects, so you can go deeper into the whole process you were looking at. We’re starting to get sort of off-topic for this thread, which is just a request for a specific edge driver.
If you end up deciding you need to start a new thread, you can put it in the following section of the forum:
Hi - I can probably help you.
The challenge with receiving values for something like temperature via HTTP is that Edge drivers cannot request a specific port number for HTTP communications. Therefore, whatever it is that is sending the requests to the Edge driver, doesn’t know what port number to use. And even if you managed to find that out, it would change any time the driver is restarted for whatever reason (hub reboot, driver update, etc.).
That may be more than you wanted to know, but with that said, there are ways around this. One is to use a simple bridging app that I have that you can run on whatever computer is sending the requests. It will act as a proxy between your app and the Edge driver, such that your app doesn’t need to know the port number.
The other solution to this is to use MQTT, which is a cleaner solution, but your sending app would need to support that.
Feel free to direct message me if you want to pursue either solution and I’m happy to help.
Ive been looking for something similar to what @Jan_Backman is asking for and hoped to find something that worked with the EdgeBridge as I already use it, @TAustin, I havn’t asked as I didnt want to appear cheeky after you very kindly created the Lan Contact Device Driver (my last request) but a Lan Temperature Device Driver with temperature and humidity support would make a great addition to the 4 already supported Lan Device Drivers…
Sure, I’ll have a look at it.
@TAustin that would be great! I have a Mac Mini that I have always up and running docker for MyQ right now so that would be just fine.
I know nothing about developing this and barely was able to get docker setup so that’s where I am at! Ha
@Jan_Backman @SlySi @Derek.Holt
A LAN Driver for receiving temperature & humidity readings via HTTP is now ready for testing. See README file here for more information. Reminder that this also pre-requisites my Edgebridge server.
Please use my Edgebridge topic for further questions/comments/help on this driver.
Has anyone attempted an Edge driver for Lutron Caseta bridge and it’s devices yet?
Hi, do you have any feedback on this?
