Thanks @Mariano_Colmenarejo
I have just checked this and verified your edge driver now works with the zbminil2 sonoff mini extreme (no neutral) switch
Dont believe what the low battery tile says to the letter, i have low battery states on various devices but they continue to work for months, battery reporting is very hit and miss
Unless it is mission critical i change batterys when the device finally dies
Hi,
Could the following device be added to a Water leak driver?
Label Leak Family Bathroom Basin
Type Tuya Leak Sensor
Version Published
Zigbee Id A4C13810359DC8E4
Device Network Id 5481
Data
application: 41
endpointId: 01
manufacturer: _TZ3000_ocjlo4ea
model: TS0207
zigbeeNodeType: SLEEPY_END_DEVICE
Raw Description 01 0104 0402 01 04 0001 0003 0500 0000 02 0019 000A
This one is now done:
Iβve got the information from Remotec. It also include and Edge Driver for ZXT-120. I didnβt checked it yetβ¦
ZXT-120 SmartThings Edge Driver Installation Guide V1.0[2763].pdf
Google Drive file.
This is the Driver invite to channel , copied from the document attached
One simple home system. A world of possibilities. | SmartThings
Build a smart home to support all your big moments. With SmartThings, your home becomes a connected space that makes your life simpler, safer, and more entertaining.
Please install and update if works or notβ¦
You save me bro thank you so much
@dotan_shai ithink we must open new topic with tath is not working directly i found a work around for me what about you?
Also searching for an edge drive for the GE tripper - If you are looking for an edge driver for the Go Control (Nortek) open close Z-Wave sensors use the one supplied here on https://community.smartthings.com by Corey Stup / I found the Z-Wave Masquerade V1.01 works great for the Go Control Open Close sensor.
Very much appreciated
Thank you I believe I have the Nortek sensor issue solved now Iβm just searching for the driver for the GE quirky tripper that will show the correct icon status
Thanks again
Dear @Mariano_Colmenarejo, I have switches from Lumi Vietnam, they are 1,2,3,4 gangs switches. Pls help me add them to your multi switches driver, I have problem with them when I can not control them invidually.
Hereafter are the info I got from IDE and Api browser.
Lumi switch 3 gangs:
Some of them I bought latter with the manufacture are Lumi Vietnam not Lumi so I need them both.
Lumi switch 2 gangs:
Lumi switch 4 gangs:
And the shade:
Thanks.
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2023-02-04T11:59:52.389548053
- id: "Lumi Vietnam/LM-SZ4"
deviceLabel: LM-SZ4 Switch
manufacturer: Lumi Vietnam
model: LM-SZ4
deviceProfileName: four-switch
- id: "Lumi Vietnam/LM-SZ2"
deviceLabel: LM-SZ2 Switch
model: LM-SZ2
deviceProfileName: two-switch
- id: "LUMI/LM-SZ3"
deviceLabel: LM-SZ3 Switch
manufacturer: LUMI
model: LM-SZ3
deviceProfileName: three-switch
Sorry, This Blind device does not have cluster 0x0102 and does not work with the stock driver or with the one that I modified
Thank you very much, I will test the driver and let you know if it works.
Any possibility of adding an edge driver for sony str-dn1080 receiver? This would be for basic LAN control.
Dear @Mariano_Colmenarejo, I Γnstalled the driver and tested with my switches. After a day of reboot the hub, clear the app cache and trial, I still need your help:
The 3 switches:
I can install this for some of my switches but there is a problem: there are 3 switches on a physical panel and 3 on the app, the first on the left maps correctly with the first switch on app. The second on the panel maps with the third switch on the app. So the second switch on app and the third button doesnβt works.
I can not have the 2 switches, 4 switches work. They keep say it offline, I tried remove and install again, reboot, clear cache, wait for a night β¦.
I still need the version with manufacture code is Lumi Vietnam for the 3 switch. (Lumi for the newer version, Lumi Vietnam for the older and I have both)
Pls add the 1 switch as follow:
Thank again.
Name Zigbee Switch Mc
Version 2023-02-05T10:18:54.951374305
- id: "Lumi Vietnam/LM-SZ1"
deviceLabel: LM-SZ1 Switch
model: LM-SZ1
deviceProfileName: single-switch
Version 2023-02-05T10:16:28.688435477
- id: "Lumi Vietnam/LM-SZ3"
model: LM-SZ3
LUMi devices may not exactly comply with zigbee standards and could use custom clusters.
I added them to the driver because I saw that it used cluster 0006, but if they donβt work Iβll need to change them to the Zigbee Thing Mc driver to see all the information about the clusters and endpoints used
The switches with manufacture code is Lumi Vietnam are not working and the later version with manufacture code Lumi is working event it share the same DTH driver.
I look inside the DTH driver code in IDE and I think I know why the working one have mapping wrong buttons, it use 1 3 5 7 endpoint not 1234β¦ (Iβm not a programmer, just see the logic of things):
def on() {
log.debug "Executing 'on' 0x${device.deviceNetworkId} endpoint 1 3 5 7"
"st cmd 0x${device.deviceNetworkId} 1 0x0006 1 {}", "delay 200",
"st cmd 0x${device.deviceNetworkId} 3 0x0006 1 {}", "delay 200",
"st cmd 0x${device.deviceNetworkId} 5 0x0006 1 {}", "delay 200",
"st cmd 0x${device.deviceNetworkId} 7 0x0006 1 {}"
About the older version which doesnβt work, could you point out what should I do? many thanks.
Iβm looking for someone to create a driver for my SureFlap Microchip Pet Door Connect. I used to be able to use the one on GitHub with limited success. Now Samsung has (as part of the ST migration) made this no longer appear as a device.
Here is a link to the product:
The pet door must use their separate hub. It works great and even has a programmable curfew and using RFID tags can control access in and out for each pet separately.
These devices require polling a cloud (Internet) service. The home assistant guys have an integration here.
Under Edge, the ST hub can only access network resources that are on the local LAN. It canβt directly query an internet API. This is by design.
Youβd need a proxy or some other relay running on your local LAN that would connect to SureCares servers in the cloud and relay the status back to ST. Similar services have been created for MyQ and other cloud based APIs.
Or youβd need to create a SmartApp that you host yourself.
Reaching out to the manufacturer to see if they would be willing to integrate at the cloud-to-cloud level with SmartThings is an option as well. Might be a good selling point for their products.
