Where can I find this driver channel? Iβve also been looking for a driver for my Z-Wave moisture detector model:
Manufacture: 0086-0002-002D
Type: ZWAVE
Model: 0002-002D
Type: ZWAVE
Model: 0002-002D
@Plasma Below is Marianos driver channel invitation link.
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
Added to this driver version
If it doesnβt work, tell me. It does not publish the supported command classes and I added it as default
ββββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Z-Wave Sensor and Child Thermostat Mc
Version 2023-12-28T18:44:58.776290138
- id: 0086/0002/002D
deviceLabel: Water Leak Sensor
manufacturerId: 0x0086
productType: 0x0002
productId: 0x002D
deviceProfileName: water-battery-tamper
Pretty sure thatβs a very old device which is a rebrand of the Aeotec DSB045. The reason you arenβt getting any command class report is because it literally only supports the βbasicβ commandset.
Itβs an even older generation than this one, but essentially the same.
https://products.z-wavealliance.org/products/1001?selectedFrequencyId=2
Hereβs a discussion from another forum
Does anyone have an edge driver for Z-wave repeaters (specifically the Aeotec Extender 7) that show signal metrics?
Hi! Does anyone have a driver for Namron z-wave thermostat? I have it installed as energy meter st the moment.
Hi @Heljar
Is your thermostat this model?
If it is and you just bought it, they have an identical zigbee model and I have a subdriver made for it in my Zigbee Thermostat Mc driver, which is tested by the user who ordered it and works fine with all functions.
Maybe you can exchange it for that model
Hi! Yes, the black version of this one. Unfortunately already installed, so stuck with itβ¦
Can you include fingerprint 010F-0303-1000 to driver Z-Wave Garage Door Opener Mc?
Hi @Tmclaussen
As I already told you privately, you want to use a fibaro roller shutter 3 to open and close a garage door.
I donβt know if that can be done or not. Some user may know how to do it.
What I do know is that I cannot add this device to the zwave garage door opener driver, since it has different command classes and it would not work.
You must use Z-Wave Window Treatment Mc driver
Is there any custom Z-Wave TRV driver that would accept the fingerprint for a new old stock EUROtronic StellaZ TRV::
DNI: 0x3D
Firmware Ver: nil * Wake Up-Refresh Device
Library Ver: nil * Wake Up-Refresh Device
Zw Protocol Ver: nil * Wake Up-Refresh
Device
Manufacturer: 0x0148
Product Type: 0x0001
Product ID: 0x0001
End Point & Command Class: [1]:
BASIC,
SWITCH_MULTILEVEL,
SENSOR_MULTILEVEL,
THERMOSTAT_MODE,
THERMOSTAT_SETPOINT,
NODE_NAMING,
BATTERY,
WAKE_UP,
MANUFACTURER_SPECIFIC,
VERSION
I have searched for the model and can only find old discussions (~2016).
There was a recent discussion about the eurotronics Spirit TRV. Maybe that driver will work for you.
Thanks for the pointer.
The StellaZ has no display. If I could get the source for the Spirit I would try playing.with it.
I will probably try hacking the SmartThings Popp TRV driver in the meantime.
I need to get my Edge development environment up and running on my new MacBook.
Cheers, Aidan
I was told you wrote a driver for the Vision ZM1601US Siren / Strobe? Apparently the advice was that it just needs the fingerprint added to work, so Iβm hoping you could do that. I was on ST 5 years ago, but when Bruceβs Rule Machine left the platform, I went to Habitat. Iβm only now coming back to ST. I had modified many groovy drivers on my own to work for various things, but the new Edge architecture is much different and really this is the only device that didnβt work out of the 100+ devices I added to the Aeotec V3 hub, I recently obtained.
Anyway, here is the info I hope helps to get this device going. I think it was originally branded as GoControl that I got many moons ago at Home Depot in a kit with some sensors. All of which I still use.
Manufacturer Code: 014F-2005-0503
Model: 2005-0503
Thanks so much in advance and if you canβt, I very much appreciate your looking.
Best!
-Bob
Hi @SuperBob
This Siren was added to my driver Z-Wave Siren Mc some days ago.
Install my driver in your Hub from my channel and install siren with search nearby option
Thatβs awesome Mariano! Iβll try it out and report back. Thanks so much
Yup, that worked! I just had to remove it and re-add it, because simply changing itβs driver didnβt give it an on/off button to work with (for the sake of anyone else that sees this). I also saw in your list of drivers one that I switched out for my First Alert ZCOMBO devices that were showing offline and that seems to work now too.
Can I ask for adding fingerprint: 013C-0004-0084 (Philio Outdoor Siren, Philio PSE04 Multiple Sound Siren User Manual) to the βz-wave siren mcβ driver? It has similar options as the one already present there:
Product id (0x0084) and the final fingerprint differs only from it, so the details would be as follows:
Thank you!
Hi,
Added to this driver version.
Try it if works
Name Z-Wave Siren Mc
Version 2024-03-22T16:42:06.16591185
- id: 013C/0004/0084
deviceLabel: Philio Siren
manufacturerId: 0x013C
productType: 0x0004
productId: 0x0084
deviceProfileName: philio-sound-siren
