Hello @Mariano_Colmenarejo ,
could you please add to the zigbee mutli switch mc the manufactur:
Manufactur:
_TZ3000_u3oupgdy
Model
TS0004
thank you very much
Manufactur:
_TZ3000_u3oupgdy
Model
TS0004
thank you very much
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2022-11-13T20:18:42.907881159
- id: "_TZ3000_u3oupgdy/TS0004"
deviceLabel: TS0004 Switch
manufacturer: _TZ3000_u3oupgdy
model: TS0004
deviceProfileName: four-switch
I am a looking for a driver for a Tuya Sprinkler Timer. Itβs a Zigbee valve that attaches to a tap.
I donβt necessarily want to do any fancy - just turn it on and off.
Here is the info it shows when connected via @ygerlovinβs Zigbee Thing driver:
@ygerlovin, @iquix, with your experience with Tuya devices, do you have anything that might work?
@Mariano_Colmenarejo, is there any way your βZigbee Valve mcβ driver would work if you added the fingerprint?
With the aproaching death of Groovy, Trendsetter will be burried along with it!
I have a bunch of Wiz lights, grouped with Trendsetter and soon I will have to find alternative!
Anyone working on something similar? If not, anyone interested?
Much appreciated!
I lost my tado connect smart app today. I have found a work around using IFTTT and Alexa to control my schedule, boost the heating and set tempatures using a combination or buttons, applets and scenes. Obviously this isnt perfect but works well.
Good day @mariano_colmenarejo, would you mind adding the Heiman Zwave indoor siren fingerprint to your driver. https://manual.zwave.eu/backend/make.php?lang=en&sku=HEIEHS2WD&cert=ZC10-18066158. I think this is the info: βzw:Ls2 type:1005 mfr:0260 prod:8009 model:1000 ver:1.02 zwv:5.03 lib:03 cc:5E,55,98,9F sec:86,25,85,8E,59,72,5A,80,73,6C,7Aβ
Thank you in advance.
Can anybody help to get Edge Drivers for the following Mydlink Z-Wave devices:
I do not if will works
Name Z-Wave Siren Mc
Version 2022-11-16T22:05:21.909658981
- id: "Heiman HEIEHS2WD Siren"
deviceLabel: Heiman HEIEHS2WD Siren
manufacturerId: 0x0260
productType: 0x8009
productId: 0x1000
deviceProfileName: base-siren
Yes, that fingerprint is in the source code for the ST zwave-lock driver.
Iβm using the Rboy Universal Z-wave Lock DTH which works well with their Lock User Manager so Iβm waiting as long as possible to migrate to the stock Edge driver.
Hi @sthubman
Name Zigbee Smoke/CO Detector Mc
Version 2022-11-17T12:32:11.826656258
- id: "HEIMAN/GASSensor-EF-3.0"
deviceLabel: HEIMAN Gas Detector
manufacturer: HEIMAN
model: GASSensor-EF-3.0
deviceProfileName: smoke
@nayelyz Any updates on Kwikset Lock Edge drivers? Seems like the stock edge driver (or Smart Guest Lock) is very limited and doesnβt have a way to program codes (unless I am totally missing it).
Hi, can you please tell me how to install it? Found the Github files, but donβt see any channel invite link.
Thank you!
I received an email from SmartThings yesterday and they informed me that I have to wait for the Gocontrol integration to happen automatically.
Hi @Mariano_Colmenarejo
I see that deviceProfileName for TS0504B has changed to level-rgb, I can not change from rgb to white level any more.
It was originally as stated above: rgbw-level-colortemp-2700-6500, but white level is fixed to 4000 in TS0505B
Possible you could change it back?
Sorry, I have not seen when this was changed.
Fixed in this version
Name Zigbee Light Multifunction Mc
Version 2022-11-20T10:41:45.082552901
- id: "_TZ3210_sroezl0s/LIDL"
deviceLabel: LIDL TS0504B
manufacturer: _TZ3210_sroezl0s
model: TS0504B
deviceProfileName: rgbw-level-colortemp-2700-6500
I have switches by TechniSat, all of them Z-Wave. I donβt know if theyβll be auto-ported or if it needs a community driver, so I just wanted to add these to the list of requests.
There are also other switches by them: 3779 (multi-way switch) and 3798 (dimmer) that are similar products made by them.
Would these work with default drivers, are there community drivers for these, or what is going to happen?
Thank you!
I have 3 kwikset locks⦠2 zwave and one zigbee. All 3 on edge drivers and can prram codes on all 3 using smart lock guest access app
