Yes, fans/lights are what I’m referring to and the fact that the documentation for this is available.
If you haven’t already, don’t forget to bug flair for a local API
I was requesting this feature, to see if it could be added as an edge driver
If you can’t find one already written, you can ask here if any community developer would be interested in creating one.
@iquix @Mariano_Colmenarejo @TAustin @ygerlovin @philh30 @veonua
Not sure if there’s already drivers available or not, but I’d be intererested in the following:
- Fibaro Wall Plug US ZW5
- Fibaro Wall Plug USB
- Iris Plug w/ ZigBee & Z-Wave Repeater featuring KWh
- Aeotec Multisensor 6
- Zooz S2 Multisiren
- Virtual Acceleration Sensor
- Momentary Button
- Device Group capabilities like TrendSetter
Any one of those would be greatly appreciated!
Zooz is working on Edge Drivers for most of their devices, but are not going to release them publicly until edge itself is out of beta.
I can look at adding an acceleration sensor to my virtual device driver. As pointed out above, momentary button is already available.
I have one of these and I’m pretty sure I put it on my GE ZigBee Switch/Dimmer driver. I think the fingerprint for mine is CentraLite 3210-L if I’m picking the right device out of the list. That driver will do power/energy for switches, but nothing else special (I don’t think that device does anything else though). If your fingerprint matches then give that a try.
I haven’t bothered with the Z-wave repeater portion. The driver wouldn’t do anything for it, so I’ll probably just wait for that to be transitioned by ST.
The Mill Wifi ovens seems to have a bit of a following and an open API:
Original request thread:
The stock Z-wave repeater edge driver works with the repeater portion of the CentraLite ZigBee plug, Z-wave repeater combo.
@Mariano_Colmenarejo @ygerlovin
Could you take a look at the fingerprint below and see if it’s possible to create a driver or add to an existing one?
It is a water leak sensor, brand ewelink… Works with DHT Everspring Flood Sensor (native)
Tks
I don’t know if I’m wrong, but the DTH that I find like, DHT Everspring Flood Sensor (native), is from a zwave device
Are you referring to another DTH?
I would love to request integration with Tado thermostat
Edge Drivers are for hub-connected devices, most commonly Zigbee or zwave. There are some LAN devices as well, but they have to have an open API. Tado does not: they only offer cloud integration. So I think the most probable path for that particular device is to contact the company and ask them to add smartthings integration. It’s not impossible that someone will come up with someway to do it from an edge driver, but it’s probably not likely.
Oh I see. Apologies I’m not very technical. I’m using the user made groovy integration, was hoping the same could be achieved with edge.
Is it possible to make a edge driver to this aqara vibration sensor ?
- zigbeeNodeType: SLEEPY_END_DEVICE
- application: 08
- endpointId: 01
- manufacturer: LUMI
- model: lumi.vibration.aq1
Raw Description 01 0104 000A 01 04 0000 0003 0019 0101 06 0000 0004 0003 0005 0019 0101
Markus
Apologies if that’s obvious, I’m not very technical. I can see there’s a lot of Ikea bulbs in your channel. Aren’t those supported by edge stock drivers? Currently in groovy I don’t need custom handles for those
Will I need custom edge drivers for ikea once groovy goes away? Will they stop native support?
It is exactly that DHT.
It’s for Z wave devices, but it’s working great for the zigbee sensor (strange, don’t you agree?)
Hold tight. ST will add this officially to the “Zwave Sensor” driver (hopefully soon) as it is a native ST local dth currently which would also include the identical Utilitec model
