I have GreenWave PowerNode 6, which is different, apparently by model number anyway, but did anyone create a driver for this? It’s been so reliable, I forgot I had it (which is hard to believe, considering it shows up as 6 separate switches)
Is it possible to create a edge virtual device that Acts like a timer? For a routine example, button x gets pressed – then-- timer/delay edge device turns on( but only turns on after x amount of time).
Is this possible?
As SHM does not have a arm delay I will have to be creative when webcore goes away.
here is a timer but doubt it works with STHM so you may want to inquire in that thread for more details or if the developer might be able to modify for your needs
I think for that purpose, The vEdge Momentary Button (Virtual Momentary Button) would do what you want, if it works with SHM, not sure one way or the other.
I did not understand your message and I apologize for this. Have you found a solution or a possible way to be able to use the LED grovee on smartthings?
LaMetric Time
I rely heavily on my LaMetric Time devices to keep me updated on what’s happening in and around my house. It tells me when the gate to my driveway is opened; an outside or garage door opens; if there is movement on the ground level after bedtime etc. I can’t imagine being without them after 30 September, and I don’t believe there is any alternative. The closest I know of, was Echo Speaks (if used with an Echo device with a screen) which is also no longer with us.
I can’t imagine why these devices are not commonly used in all home automation setups. I suppose the price could be a reason.
The LaMetric required a SmartApp and device driver to function. I haven’t figured out how devices which required SmartApps in the past, will work in the new environment.
I wish I knew this device existed. I have been thinking about making something like this out of a small LED strip. I hope someone makes an Edge Driver for this. Also for the HomeSeer HS-FS100-L Z-Wave Dual Sensor & Buzzer.
A request for an edge driver for the Zwave Greenwave single node power socket, the device does have a few settings available, or at least it used to have in the Smartthings original app, since then the available config options and UI components have not been available
Original DTH with pictures of available options in the UI
I would also want this integration to the monoprice 6 zone amp… This integration will completely stop working in about a month. Anyone has any ideas/suggestions?
Added to this driver version
Please,Try and tell me if works
│ Name │ Z-Wave Switch Mc │
│ Version │ 2022-08-25T21:16:15.719160733 │
