Post Requests for Edge Drivers Here (community-created)
Hi.
Iv`e been looking for a driver for Namron 4ch button. cant seem to find it.
can anyone help me?
https://products.z-wavealliance.org/products/3639
zwaveManufacturer:
  • id: “Namron/4kanal”
    deviceLabel: Namron 4 Kanal
    manufacturerId: 0x0438
    productType: 0x0300
    productId: 0xa305
    deviceProfileName: namron-4kanal
It’s exactly the same button as Heatit’s channel buttons.
My bedroom is now dark, no problem when i got Google or the phone, but would be great to have my batteryoperated switches working again.
Aleksander
Hi @eric182
This device exist in stock Z-Wave Button driver and my driver Z-Wave Button Mc
It should pair with either one you have installed on your Hub.
I have both of those edge drivers you just mentioned. One of my minimotes did join with your edge driver. The others joined back as non-edge devices and it just says “Z wave device.”
This has happened to me once and it has been because it has not been paired correctly due to being far from the Hub.
For that device my driver does not add anything new, if all your buttons are included in the stock driver, you can delete mine and have only one stock driver installed
But that’s just it- it’s not joining as the stock z wave button either. It get added to the system as an an old groovy device after being reset.
Prior to resetting it, it worked as should. It was a normal minimote.
After I reset the device and add it back to the system, it adds as this:
It’s not adding back as an edge driver at all. It’s not even adding back as what it formally once was.
There’s already a discussion thread on this issue, multiple people have reported it. Sounds like there may be multiple fingerprints with only some being picked up.
Help with aeon minimote
Looking for a driver for an Iris / Centralite Zigbee Keypad that will work to arm and disarm STHM. Had been using Rboy’s zigbee driver and keypad smartapp combo, but I don’t think it’s going to make the transition to Edge.
It can be simple - single code for access, just need the disarm, arm/stay, arm/away functionality. Would be nice to have the panic. But that’s it.
This is about the only device I’m worried about as part of this transition, as this is the way the family interacts with STHM.
Thanks!
Does anyone have smart recessed lights but not color? I am using the driver for zigbee lights for my light strip & so far so good, but when i went to reset my halo non color recessed light, it took that driver, but there are no adjustments for the different levels of white lighting. The halo light would let me change those.
Install @Mariano_Colmenarejo “ZigBee Light Multifunction Mc” Edge Driver and try manually switching the driver on your Halo lights to that driver.
That should fix your problem. If not @Mariano_Colmenarejo is very good about helping people out.
I have that & was able to figure it out. Thank you.
Im looking for an Edge driver for a HS-FS100-W. I have no custom DTH and it adds as a legacy door window sensor. I added a generic zwave sensor to my drivers and then it added as a swave sensor, but it doesnt show as a water leak sensor.
zw:Ls2a type:0701 mfr:0315 prod:0202 model:0001 ver:50.07 zwv:6.02 lib:03
Is there an Edge driver for Xiaomi Aqara Curtain ZigBee motor model ZNCLDJ11LM? Thanks.
Name Xiaomi Curtain SJ
Mfg Name SmartThings
Mfg Code LUMI
Model lumi.curtain
ocf Type oic.d.blind
Category Blind
Presentation ID SmartThings-smartthings-Springs_Window_Fashions_Shade
Type DTH
Network Type ZIGBEE
Type Name Xiaomi Curtain Aqara
Local Execution no
Hi,
Im looking for custom Edge driver for 3A Nue zigbee 2,3 4 gang switches and 2 gand GPO outlet.
Currently they are not matching to an edge driver after removing the DTH. Just as a switch with only 1 gang, so loss of function.
( was able to republish this a while ago. But with the recent changes im reluctant to remove the DTH again as im unsure id be abke to republish it.)
Been looking at editing writing my own, after many searches couldnt find one, but wanted to try here, as per the guide at the top details below
3A : Nue ZigBee Multi Switch
Hi @Aran_Simm
It is necessary that you publish the fingerprints, manufacturer, model and cluster of the devices.
You can install the Zigbee Thing Mc driver and pair it with it to see the information.
Some of them are already collected in the Zigbee Multi Switch and Child Mc driver, like the one you posted, 2 gangs switch
- id: "3A Smart/LXN2S2"
    deviceLabel: 3A Smart 2 Switch
    manufacturer: 3A Smart Home DE
    model: LXN-2S27LX1.0
    deviceProfileName: two-switch
Hi @Mariano_Colmenarejo , thanks for this advice. Ive installed the driver. But having trouble pairing to the driver. To get this info.
Must i remove all custom device handlers? And then pair the device again.
Or is there a way to manually assign it?
( aplogies to the community if these are ttoo basic a question to ask)
I think yes, you must remove the custom DTH
HI @Mariano_Colmenarejo ,
I performed the remove Device handler task, installed and enrolled the folllowing deivers from your channel
Motion
Contact
Thing
And all of my Nue 3A switch devices are working well. Even the 2, 3 and 4 gang devices.
A Massive thank you and appreciation for your efforts in supporting these devices!!!
Some notes of advice for users around my level of expertise, ( low-mid level), i couldnt find these small tops anywhere else so wanted to post them for others.
1.I was very reluctant , and had delayed performing this work to because if the drivers didnt pick up the device, id have been in a difficult spot. But the response time from the community posts was so quick id encourage others to take the plunge.
2.Marianos Zigbee Thing Mc driver needs to be manually selected, and this can only be done when its already on another driver. ( i was trying to find a way to manually select it when i still had my old DTHs installed.) This is shown in the settings of the device under driver as below.
I now understand this driver is like a universal fallback to at least get the main cluster and device id information, ,( that wasnt clear to me before) if another driver doesnt work.
  1. For the multi switches there is an options setting to Create single device for Switch X. Took me a while to find it. But in case this is your preference.
Aran.
Any chance getting a edge driver updated for the Monoprice tilt sensor? The stock edge driver from Smartthings does not work correctly, it opens fine but on close, it closes then sets the status to open for about 30 minutes. Here is the raw data.
Raw Description zw:S type:2001 mfr:0109 prod:200A model:0A02 ver:4.84
Chris
For anyone who is looking for driver for Monoprice 24259. I am using @philh30 's Z-wave Masquerade v1.01.
How long did it take for battery % to be updated? I switched one over to Edge a couple of hours ago and Battery hasnt updated.
