Title says it all. I’m looking to see if it is possible to pause STHM monitoring, specifically for leak detection using a routine.
Not directly.
Routines can only arm/disarm it, from what I know. They can’t even dismiss the alarm once it activates.
I suppose you could do something with routines with a virtual leak detector:
That is, a routine that takes the input from your real leak detector and outputs it to a virtual one. The virtual one becomes the input to STHM. You could have a virtual switch to turn that routine on/off.
Yeah, I was expecting that was going to be the answer. I’ll probably end up just creating a virtual water value with a routine to only close the real value if the hub isn’t set to a specific mode.
