Hey all,
I’m looking for some advice on building a Z-Wave gate buzzer with a keypad.
The way my gate is currently set up doesn’t easily allow for a full Z-Wave lock. It uses a low-voltage latch connected to a momentary push button. Holding the button down releases the latch and opens the gate, and releasing the button locks it again.
Here’s what I’m thinking:
- Enter a code on the keypad.
- A relay activates the buzzer to release the gate latch (I’m considering using a Shelly device that I could potentially use for my garage door as well).
- Optionally, a z wave chime sounds to indicate the gate has been opened
- The buzzer remains “on” until a door contact closes or a preset timeout is reached, at which point the latch locks again.
Ideally, I’d also like to retain the existing manual push button.
I’ve come across a few threads discussing similar setups, but none using a keypad. Has anyone tried something like this, or is it even possible? I’m also open to other approaches that may be less complicated.
Thanks in advance
