I have talked about this issue in 2 other threads (Iris Motion & Bosch Motion), but realized tonight I think the issue might be unrelated to those devices, so thought I should make a new thread.
I had 2 motion sensors in my basement have a problem where they keep registering motion where none is occurring (nor any major heat changes), and it happens consistently. For the Bosch it is every 3 min since that is the min timeout. For the Iris it varies from 1-3 minutes. I have noticed if a different type of event (temp change or battery level) is recorded it seems to stop briefly, but then resumes. I have found that when I bring them back upstairs sometimes they behave and sometimes not. I have other devices in the basement that are working great. 2 Iris motion, 2 Sengled Bulb, and 1 Centralite outlet. I also have Z-wave devices down there and those are fine too. It dawned on me that maybe this is a repeater problem, but that doesn’t make sense if all the other devices are working fine. I also recently upgraded to Google Wifi and have a hub down there so maybe that’s a factor. Tonight I reset the Centralite outlet and also powered the hub off for 20 min to do a zigbee heal. Bosch sensor now works fine downstairs but the Iris was still acting up so I brought upstairs and it started to behave. Took it back downstairs and its behaving there too. Its all just so very weird. Anyone have any suggestions?
