Hi!
I found a Hubitat driver for the Popp Z-rain sensor. When I try to convert it to a Smartthings device handler I get an error message according to below. Anyone that are able to help me? It would be highly appreciated!
Org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script_dth_metadata_ed7d6c38_bc91_4ccf_9559_564cfd146ac9: 387: The method public void zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd) { … } duplicates another method of the same signature . At [387:1] @ line 387, column 1. void zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd) { ^ 1 error
Original Hubitat driver:
My attempt for Smartthings:
- Copyright © Sebastian YEPES - ported to Smartthings by Str2der
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
import groovy.transform.Field
@Field String VERSION = “1.1.1”
@Field List LOG_LEVELS = [“error”, “warn”, “info”, “debug”, “trace”]
@Field String DEFAULT_LOG_LEVEL = LOG_LEVELS[1]
metadata {
definition (name: “Popp Z-Rain Sensor”, namespace: “syepes”, author: “Sebastian YEPES”) {
capability “Actuator”
capability “Battery”
capability “Power Source”
capability “Sensor”
capability “Refresh”
capability “Configuration”
capability “Initialize”
command “clearState”
attribute "rainMeter", "number"
attribute "rainRate", "number"
attribute "rainTotal", "number"
attribute "rain", "enum", ["true","false"]
attribute "rainHeavy", "enum", ["true","false"]
fingerprint mfr:"0154", prod:"0004"
fingerprint deviceId: "17", inClusters: "0x5E, 0x31, 0x70, 0x85, 0x80, 0x84, 0x32, 0x7A, 0x5A, 0x59, 0x73, 0x86, 0x72"
preferences {
section { // General
input name: “logLevel”, title: “Log Level”, type: “enum”, options: LOG_LEVELS, defaultValue: DEFAULT_LOG_LEVEL, required: false
input name: “logDescText”, title: “Log Description Text”, type: “bool”, defaultValue: false, required: false
section { // Configuration
input name: “batteryCheckInterval”, title: “Battery Check”, description: “Check interval of the battery state”, type: “enum”, options:[[0:“Disabled”], [1:“1h”], [2:“2h”], [3:“3h”], [4:“4h”], [6:“6h”], [8:“8h”], [12: “12h”], [24: “24h”]], defaultValue: 12, required: true
input name: “wakeUpInterval”, title: “Device Wake Up Interval”, description: “”, type: “enum”, options:[[15:“15m”], [30:“30m”], [60:“1h”], [120:“2h”], [180:“3h”], [240:“4h”], [480:“8h”], [720:“12h”], [1440: “24h”], [2880: “48h”]], defaultValue: 30, required: true
input name: “param1”, title: “Rain Counter”, description: “Initial rain counter from the moment of inclusion in mm water level. By setting this value the counter will be reseted, it should be empty to leave the counter unchanged”, type: “number”, range: “0…32000”, defaultValue: ‘’, required: false
input name: “param4”, title: “Meter Multiplier”, description: “This multiplier allows to adapt the display to certain controllers not being able to handle very low numbers”, type: “enum”, options:[[1:“1”], [10:“10”], [100:“100”], [1000:“1000”]], defaultValue: 1, required: true
input name: “param6”, title: “Heavy Rain Start Command”, description: “This BASIC Set Command value is sent out into Association Group 3 when the device detects start of heavy rain”, type: “number”, range: “0…99”, defaultValue: 99, required: true
input name: “param7”, title: “Heavy Rain Stop Command”, description: “This BASIC Set Command value is sent out into Association Group 3 when the device detects stop of heavy rain”, type: “number”, range: “0…99”, defaultValue: 1, required: true
input name: “param5”, title: “Heavy Rain”, description: “This threshold defines when a heavy rain condition is hit. In most countries this is defined as > 15 mm rain per hour. The default value however is to turn this function off (256)”, type: “number”, range: “0…256”, defaultValue: 25, required: true
input name: “param2”, title: “Rain Start Command”, description: “This BASIC Set Command value is sent out into Association Group 2 when the device detects start of rain”, type: “number”, range: “0…99”, defaultValue: 98, required: true
input name: “param3”, title: “Rain Stop Command”, description: “This BASIC Set Command value is sent out into Association Group 2 when the device detects stop of rain”, type: “number”, range: “0…99”, defaultValue: 0, required: true
def installed() {
logger(“debug”, “installed(${VERSION})”)
if (state.driverInfo == null || state.driverInfo.isEmpty() || state.driverInfo.ver != VERSION) {
state.driverInfo = [ver:VERSION, status:‘Current version’]
state.driverInfo.configSynced = false
if (state.deviceInfo == null) {
state.deviceInfo = [:]
initialize()
def initialize() {
logger(“debug”, “initialize()”)
def updated() {
logger(“debug”, “updated()”)
if (!state.driverInfo?.ver || state.driverInfo.isEmpty() || state.driverInfo.ver != VERSION) {
installed()
unschedule()
configure()
def refresh() {
logger(“debug”, “refresh() - state: ${state.inspect()}”)
state.deviceInfo.lastbatt = now()
updateDataValue(“MSR”, “”)
def configure() {
logger(“debug”, “configure()”)
schedule(“0 0 12 */7 * ?”, updateCheck)
logger(“info”, “Device configurations will be synchronized on the next device wakeUp”)
def clearState() {
logger(“debug”, “ClearStates() - Clearing device states”)
state.clear()
if (state?.driverInfo == null) {
state.driverInfo = [:]
} else {
state.driverInfo.clear()
if (state?.deviceInfo == null) {
} else {
state.deviceInfo.clear()
installed()
logger(“debug”, “parse() - description: ${description?.inspect()}”)
def result =
def cmd = zwave.parse(description, getCommandClassVersions())
if (cmd) {
result = zwaveEvent(cmd)
logger(“debug”, “parse() - parsed to cmd: {cmd?.inspect()} with result: {result?.inspect()}”)
} else {
logger(“error”, “parse() - Non-parsed - description: ${description?.inspect()}”)
result
def zwaveEvent(physicalgraph.zwave.commands.associationv2.AssociationReport cmd) {
logger(“trace”, “zwaveEvent(AssociationReport) - cmd: ${cmd.inspect()}”)
def result =
if (cmd.nodeId.any { it == zwaveHubNodeId }) {
logger(“info”, “Is associated in group {cmd.groupingIdentifier}")
} else if (cmd.groupingIdentifier == 1) {
logger("info", "Associating in group {cmd.groupingIdentifier}”)
result << response(zwave.associationV2.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
result
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
logger(“trace”, “zwaveEvent(ConfigurationReport) - cmd: ${cmd.inspect()}”)
def zwaveEvent(physicalgraph.zwave.commands.deviceresetlocallyv1.DeviceResetLocallyNotification cmd) {
logger(“trace”, “zwaveEvent(DeviceResetLocallyNotification) - cmd: ${cmd.inspect()}”)
logger(“warn”, “Has reset itself”)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalGet cmd) {
logger(“trace”, “zwaveEvent(WakeUpIntervalGet) - cmd: ${cmd.inspect()}”)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalReport cmd) {
logger(“trace”, “zwaveEvent(WakeUpIntervalReport) - cmd: {cmd.inspect()}")
logger("info", "Device wakup interval: {cmd.seconds}”)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd) {
logger(“trace”, “zwaveEvent(WakeUpNotification) - cmd: ${cmd.inspect()}”)
logger(“info”, “Device woke up”)
def cmds =
def result =
cmds = cmds + cmdSequence([
zwave.meterV4.meterGet(scale: 0), // Water meter
zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: 0) // Rain rate
], 300)
// Only send config if not synced
if (!state?.driverInfo?.configSynced) {
logger(“info”, “Synchronizing device config”)
zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId),
zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId),
zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:zwaveHubNodeId),
zwave.wakeUpV2.wakeUpIntervalSet(seconds:wakeUpInterval.toInteger() * 60, nodeid:zwaveHubNodeId),
zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, scaledConfigurationValue: param2.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: param3.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 4, size: 2, scaledConfigurationValue: param4.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 5, size: 1, scaledConfigurationValue: param5.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 6, size: 1, scaledConfigurationValue: param6.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 7, size: 1, scaledConfigurationValue: param7.toInteger())
], 300)
if (param1 != null && param1 != '') {
logger("info", "Resetting Rain Counter to ${param1}")
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 2, scaledConfigurationValue: param1.toInteger())
], 100)
state.driverInfo.configSynced = true
// Refresh if MSR is not set
if (!getDataValue(“MSR”)) {
logger(“info”, “Refresing device info”)
zwave.versionV2.versionGet(),
zwave.firmwareUpdateMdV2.firmwareMdGet(),
zwave.manufacturerSpecificV1.manufacturerSpecificGet(),
zwave.powerlevelV1.powerlevelGet()
], 100)
// Check battery level only once every Xh
if (batteryCheckInterval?.toInteger()) {
if (!state?.deviceInfo?.lastbatt || now() - state.deviceInfo.lastbatt >= batteryCheckInterval?.toInteger() 6060*1000) {
cmds = cmds + cmdSequence([zwave.batteryV1.batteryGet()], 100)
cmds = cmds + cmdSequence([zwave.wakeUpV2.wakeUpNoMoreInformation()], 500)
result = result + response(cmds)
result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
logger(“trace”, “zwaveEvent(BasicSet) - cmd: ${cmd.inspect()}”)
def result =
Map map = [displayed: true]
switch (cmd?.value) {
case “{param2}":
map.name = "rain"
map.value = true
map.descriptionText = "It has started raining (Normal)"
break
case "{param3}”:
map.name = “rain”
map.value = false
map.descriptionText = “It has stopped raining (Normal)”
break
case “{param6}":
map.name = "rainHeavy"
map.value = true
map.descriptionText = "It has started raining (Heavy)"
break
case "{param7}”:
map.name = “rainHeavy”
map.value = false
map.descriptionText = “It has stopped raining (Heavy)”
break
default:
logger(“warn”, “zwaveEvent(BasicSet) - Unknown value: ${cmd?.value}”)
break;
if(logDescText && map?.descriptionText) {
log.info “{device.displayName} {map.descriptionText}”
} else if(map?.descriptionText) {
logger(“info”, “${map.descriptionText}”)
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
logger(“trace”, “zwaveEvent(BasicReport) - cmd: ${cmd.inspect()}”)
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
logger(“trace”, “zwaveEvent(MeterReport) - cmd: ${cmd.inspect()}”)
def result =
List meterTypes = [“Unknown”, “Electric”, “Gas”, “Water”]
List waterUnits = [“m^3”, “ft^3”, “gal”]
if (cmd.meterType == 3) { // water
logger(“debug”, “zwaveEvent(MeterReport) - deltaTime:{cmd.deltaTime} secs, meterType:{meterTypes[cmd.meterType]}, meterValue:{cmd.scaledMeterValue}, previousMeterValue:{cmd.scaledPreviousMeterValue}, scale:{cmd.scale}, unit: {waterUnits[cmd.scale]}, precision:{cmd.precision}, rateType:{cmd.rateType}”)
def map = [name: “rainMeter”, value: cmd.scaledMeterValue, unit: waterUnits[cmd.scale], displayed: true]
result << createEvent(map)
if(logDescText) {
log.info “{device.displayName} {meterTypes[cmd.meterType]} {map.name} is {map.value} {map.unit}"
} else {
logger("info", "{meterTypes[cmd.meterType]} {map.name} is {map.value} ${map.unit}”)
} else {
logger(“warn”, “zwaveEvent(MeterReport) - Unknown meterType: ${cmd.meterType}”)
result
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
logger(“trace”, “zwaveEvent(SensorMultilevelReport) - cmd: ${cmd.inspect()}”)
def cmds =
Map map = [sensorType: cmd.sensorType, scale: cmd.scale, displayed: true]
switch (cmd.sensorType) {
case 2: // General Purpose (V1)
map.name = “rainTotal”
map.unit = (cmd.scale == 1) ? “” : “%”
map.precision = cmd.precision
map.value = cmd.scaledSensorValue.toFloat() * cmd?.precision?.toInteger()
map.descriptionText = “Water {map.name} is {map.value} {map.unit}"
break
case 0xC: // 12 = Rain Rate (V2)
map.name = "rainRate"
map.unit = (cmd.scale == 1) ? "in/h" : "mm/h"
map.descriptionText = "Water {map.name} is {map.value} {map.unit}”
break
default:
logger(“warn”, “zwaveEvent(SensorMultilevelReport) - Unknown sensorType: ${cmd.sensorType}”)
break;
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
logger(“trace”, “zwaveEvent(BatteryReport) - cmd: ${cmd.inspect()}”)
Map map = [ name: “battery”, unit: “%” ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = “Has a low battery”
map.isStateChange = true
logger(“warn”, “${map.descriptionText}”)
} else {
map.value = cmd.batteryLevel
map.descriptionText = “Battery is {cmd.batteryLevel} {map.unit}”
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.powerlevelv1.PowerlevelReport cmd) {
logger(“trace”, “zwaveEvent(PowerlevelReport) - cmd: ${cmd.inspect()}”)
String power = (cmd.powerLevel > 0) ? “minus${cmd.powerLevel}dBm” : “NormalPower”
logger(“debug”, “Powerlevel Report: Power: {power}, Timeout: {cmd.timeout}”)
def zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd) {
logger(“trace”, “zwaveEvent(VersionReport) - cmd: ${cmd.inspect()}”)
state.deviceInfo[‘applicationVersion’] = “{cmd.applicationVersion}"
state.deviceInfo['applicationSubVersion'] = "{cmd.applicationSubVersion}”
state.deviceInfo[‘zWaveLibraryType’] = “{cmd.zWaveLibraryType}"
state.deviceInfo['zWaveProtocolVersion'] = "{cmd.zWaveProtocolVersion}”
state.deviceInfo[‘zWaveProtocolSubVersion’] = “${cmd.zWaveProtocolSubVersion}”
updateDataValue(“firmware”, “{cmd.applicationVersion}.{cmd.applicationSubVersion}”)
def zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionCommandClassReport cmd) {
logger(“trace”, “zwaveEvent(VersionCommandClassReport) - cmd: ${cmd.inspect()}”)
state.deviceInfo[‘commandClassVersion’] = “{cmd.commandClassVersion}"
state.deviceInfo['requestedCommandClass'] = "{cmd.requestedCommandClass}”
Double firmware0Version = cmd.firmware0Version + (cmd.firmware0SubVersion / 100)
Double protocolVersion = cmd.zWaveProtocolVersion + (cmd.zWaveProtocolSubVersion / 100)
updateDataValue(“firmware”, “${firmware0Version}”)
state.deviceInfo[‘firmwareVersion’] = firmware0Version
state.deviceInfo[‘protocolVersion’] = protocolVersion
state.deviceInfo[‘hardwareVersion’] = cmd.hardwareVersion
if (cmd.firmwareTargets > 0) {
cmd.targetVersions.each { target ->
Double targetVersion = target.version + (target.subVersion / 100)
state.deviceInfo[“firmware${target.target}Version”] = targetVersion
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.DeviceSpecificReport cmd) {
logger(“trace”, “zwaveEvent(DeviceSpecificReport) - cmd: ${cmd.inspect()}”)
state.deviceInfo[‘deviceIdData’] = “{cmd.deviceIdData}"
state.deviceInfo['deviceIdDataFormat'] = "{cmd.deviceIdDataFormat}”
state.deviceInfo[‘deviceIdDataLengthIndicator’] = “l${cmd.deviceIdDataLengthIndicator}”
state.deviceInfo[‘deviceIdType’] = “${cmd.deviceIdType}”
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
logger(“trace”, “zwaveEvent(ManufacturerSpecificReport) - cmd: ${cmd.inspect()}”)
state.deviceInfo[‘manufacturerId’] = “{cmd.manufacturerId}"
state.deviceInfo['productId'] = "{cmd.productId}”
state.deviceInfo[‘productTypeId’] = “${cmd.productTypeId}”
String msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue(“MSR”, msr)
if (cmd?.manufacturerName && cmd?.manufacturerName != “”) {
updateDataValue(“manufacturer”, cmd.manufacturerName)
state.deviceInfo[‘manufacturerName’] = “${cmd.manufacturerName}”
} else if (cmd?.manufacturerId != “”) {
updateDataValue(“manufacturer”, cmd?.manufacturerId?.toString())
def zwaveEvent(physicalgraph.zwave.commands.firmwareupdatemdv2.FirmwareMdReport cmd) {
logger(“trace”, “zwaveEvent(FirmwareMdReport) - cmd: ${cmd.inspect()}”)
state.deviceInfo[‘firmwareChecksum’] = “{cmd.checksum}"
state.deviceInfo['firmwareId'] = "{cmd.firmwareId}”
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
logger(“trace”, “zwaveEvent(SecurityMessageEncapsulation) - cmd: ${cmd.inspect()}”)
setSecured()
def encapsulatedCommand = cmd.encapsulatedCommand(getCommandClassVersions())
if (encapsulatedCommand) {
logger(“trace”, “zwaveEvent(SecurityMessageEncapsulation) - encapsulatedCommand: {encapsulatedCommand}")
zwaveEvent(encapsulatedCommand)
} else {
logger("warn", "zwaveEvent(SecurityMessageEncapsulation) - Unable to extract Secure command from: {cmd.inspect()}”)
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
logger(“trace”, “zwaveEvent(Crc16Encap) - cmd: ${cmd.inspect()}”)
def encapsulatedCommand = zwave.getCommand(cmd.commandClass, cmd.command, cmd.data)
logger(“trace”, “zwaveEvent(Crc16Encap) - encapsulatedCommand: {encapsulatedCommand}")
} else {
logger("warn", "zwaveEvent(Crc16Encap) - Unable to extract CRC16 command from: {cmd.inspect()}”)
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
logger(“trace”, “zwaveEvent(MultiChannelCmdEncap) - cmd: ${cmd.inspect()}”)
logger(“trace”, “zwaveEvent(MultiChannelCmdEncap) - encapsulatedCommand: {encapsulatedCommand}")
zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint as Integer)
} else {
logger("warn", "zwaveEvent(MultiChannelCmdEncap) - Unable to extract MultiChannel command from: {cmd.inspect()}”)
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
logger(“trace”, “zwaveEvent(SecurityCommandsSupportedReport) - cmd: ${cmd.inspect()}”)
setSecured()
def zwaveEvent(physicalgraph.zwave.commands.securityv1.NetworkKeyVerify cmd) {
logger(“trace”, “zwaveEvent(NetworkKeyVerify) - cmd: ${cmd.inspect()}”)
logger(“info”, “Secure inclusion was successful”)
setSecured()
logger(“warn”, “zwaveEvent(Command) - Unhandled - cmd: ${cmd.inspect()}”)
private cmd(physicalgraph.zwave.Command cmd) {
logger(“trace”, “cmd(Command) - cmd: {cmd.inspect()} isSecured(): {isSecured()} S2: ${getDataValue(“S2”)}”)
if (getDataValue(“zwaveSecurePairingComplete”) == “true” && getDataValue(“S2”) == null) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else if (getDataValue(“zwaveSecurePairingComplete”) == “true”) {
zwaveSecureEncap(cmd)
} else {
cmd.format()
String secure(String cmd) {
logger(“trace”, “secure(String) - cmd: ${cmd.inspect()}”)
return zwaveSecureEncap(cmd)
String secure(physicalgraph.zwave.Command cmd) {
logger(“trace”, “secure(Command) - cmd: ${cmd.inspect()}”)
private cmdSequence(Collection commands, Integer delayBetweenArgs=250) {
logger(“trace”, “cmdSequence(Command) - commands: {commands.inspect()} delayBetweenArgs: {delayBetweenArgs}”)
delayBetween(commands.collect{ cmd(it) }, delayBetweenArgs)
private setSecured() {
updateDataValue(“zwaveSecurePairingComplete”, “true”)
private isSecured() {
private getCommandClassVersions() {
return [0x5E: 1, // COMMAND_CLASS_ZWAVEPLUS_INFO (Insecure)
0x31: 5, // COMMAND_CLASS_SENSOR_MULTILEVEL
0x70: 1, // COMMAND_CLASS_CONFIGURATION_V2 (Secure)
0x85: 2, // COMMAND_CLASS_ASSOCIATION (Secure)
0x80: 1, // COMMAND_CLASS_BATTERY
0x84: 2, // COMMAND_CLASS_WAKE_UP_V2
0x32: 4, // COMMAND_CLASS_METER
0x7A: 2, // COMMAND_CLASS_FIRMWARE_UPDATE_MD (Insecure)
0x5A: 1, // COMMAND_CLASS_DEVICE_RESET_LOCALLY (Insecure)
0x59: 1, // COMMAND_CLASS_ASSOCIATION_GRP_INFO (Secure)
0x73: 1, // COMMAND_CLASS_POWERLEVEL (Insecure)
0x86: 1, // COMMAND_CLASS_VERSION (Insecure)
0x72: 2 // COMMAND_CLASS_MANUFACTURER_SPECIFIC (Insecure)
- @param level Level to log at, see LOG_LEVELS for options
@param msg Message to log
private logger(level, msg) {
if (level && msg) {
Integer levelIdx = LOG_LEVELS.indexOf(level)
Integer setLevelIdx = LOG_LEVELS.indexOf(logLevel)
if (setLevelIdx < 0) {
setLevelIdx = LOG_LEVELS.indexOf(DEFAULT_LOG_LEVEL)
if (levelIdx <= setLevelIdx) {
log."{level}" "{device.displayName} ${msg}"
