A USB Plug-in adapter +
(or similar) should solve the problem.
You’ll need to solder a couple or wires but the sensor can be placed anywhere.
So get a 12vdc (or within the range) power supply and insert this between the hot side of the power supply and the positive terminal of sensor, then common of supply direct to negative terminal of sensor???
Are thermostats run off 12vdc? Be a nice place to put sensor and easy to grab 12v (since we had to run a common for the smart ones already anyway)…
Yes, you connect -PS to Common of Regulator and to ‘-’ of the sensor.
+PS goes to Regulator IN+.
Regulator OUT+ -> ‘+’ of the sensor.
Known to me thermostats run on 24VAC. You’ll need a rectifier + filtering capacitors. Regulators with wider ranges of Input voltages certainly exist but I am not sure they will easily go into the sensor’s battery compartment.
Thanks for the link. Just ordered two to see if I can get the arrival sensor on the 12V from the car.
Those are a battery drain especially when it is cold out.
give me your thoughts on this…
I recently purchased this 4V 100mA solar panel
(which I know never runs full power unless in direct sunlight) - this is behind glass/inside/facing out.
and these 3.6V LIR2450 coin cells
and soldered the s-panel to the sensor. Stupid simple. BUT…
What problems (if any) do you foresee? I know enough about electricity to be “dangerous”.
My goal is not to replace the power ('cause clearly that would only work on a sunny day).
Instead, to keep it topped off.
If it can maintain a full charge, then cold dips and constant replacements would be a thing of the past.
At the moment, it’s working fine AND the battery is fully charged, so I won’t know for a while… BUT, the sensor is constantly in use (multipurpose motion) in a high traffic area.
Let the flames begin! (you only learn by failing)
The problem is, as Robert Heinlein pointed out many years ago:
stupidity is always fatal. Unfortunately, it doesn’t always get the right person.
This is particularly true for fire safety. For the sake of all your neighbours, some of whom might need assistance to evacuate in the event of a fire, find another way.
so, is it logical to assume that a button cell and a solar panel in a 2in plastic box is likely to catch fire vs melt or just short?
Just trying t become less stupid.
A short always represents a fire hazard.
But, yes, batteries do burn. As Samsung knows very well.
Would either of you have a suggestion for the smallest protection circuit I could place in between without to much bulk for the two items above?
side note… I also considered cannibalizing a refurb I bought of my fav keyboard:
Thinking it might have everything I need and charge under better circumstances.
However, the b-cell is a 2032 instead of the S.T. 2450… so I wasn’t sure if it would be a straight up swap and just charge slower.
also… is it likely the battery will ever be full, what with the constant use of it as a multipurpose device?
That’s where my mind org. came from as, expecting it will keep it “topped off - lose term” but never full or “over” even for a rechargeable.
honestly, I’d be lucky to get 6-9 months. WA state.
'specially in the cold months.
The device(s) bat threshold seems to be SO low, that I get false positives all the time if the battery is not brand spakin’ new!
The only bats that last that long (of all my S.T. device(s)) are the leak sensors.
*likely 'cause they are a bit more insulated.
Needless to say, it’s a little frustrating.
Which ties into why and cheap… 'cause constantly replacing them with something that came factory full vs always “topped off -loosely”, seems more accurate, useful and less a PITA.
As for cleaning the panel, it’s in the window (inside the house)… so it’s not going to get dirty easily/less rare dust.
