SalesForce.com is returning “Bad Request” for RESTful login requests from a SmartApp.
The same request works from curl.
I have tried many variations and carefully compared the curl request to corresponding SmartApp request using RequestBin.
What am I doing wrong?
def login() {
log.debug "login called."
This code is based upon documentation at
http://docs.smartthings.com/en/latest/smartapp-developers-guide/calling-web-services-in-smartapps.html
and answer from Mohith Shrivastava at
http://salesforce.stackexchange.com/questions/5925/oauth-2-0-username-password-flow-problem-unsupported-grant-type.
String reqbody = 'grant_type=password' +
'&client_id=' + appSettings.client_id +
'&client_secret=' + appSettings.client_secret +
'&username=' + appSettings.username +
'&password=' + appSettings.password + appSettings.security_token
// Send request to RequestBin for inspection.
def params = [
uri: 'http://requestb.in/',
path: appSettings.requestBin,
requestContentType: 'application/x-www-form-urlencoded',
body: reqbody
log.debug "params: $params"
try {
httpPostJson (params) {resp ->
log.debug "RequestBin succesful."
} catch (e) {
log.error "RequestBin error: $e"
// Send the request to SalesForce.
params = [
uri: 'https://login.salesforce.com/',
path: 'services/oauth2/token',
body: reqbody
try {
log.debug "todo: Parse SalesForce response and return access token."
} catch (e) {
log.error "login error: $e"
b5dfd35d-9491-4c85-b923-ab4ed9dba888 10:08:12 AM: error login error: groovyx.net.http.HttpResponseException: Bad Request
b5dfd35d-9491-4c85-b923-ab4ed9dba888 10:08:12 AM: debug params: [uri:https://login.salesforce.com/, path:services/oauth2/token, requestContentType:application/x-www-form-urlencoded, body:grant_type=password&client_id=<client_id>&client_secret=<client_secret>&username=&password=4RXqSl3bdyFsjZqZSC2Fls60]
b5dfd35d-9491-4c85-b923-ab4ed9dba888 10:08:12 AM: debug RequestBin succesful.
b5dfd35d-9491-4c85-b923-ab4ed9dba888 10:08:08 AM: debug params: [uri:http://requestb.in/, path:15wvsgu1, requestContentType:application/x-www-form-urlencoded, body:grant_type=password&client_id=<client_id>&client_secret=<client_secret>&username=&password=4RXqSl3bdyFsjZqZSC2Fls60]
b5dfd35d-9491-4c85-b923-ab4ed9dba888 10:08:08 AM: debug login called.
