Just rebuilt the device list today and linked the SmartThings hub to Echo. Worked very well and it implements the dimming commands! I did have to delete some duplicate devices that got picked up from both the Hue Hub and the ST hub. Fortunately the Alexa app now lets you forget individual devices. Hue bridge did a great job for me waiting for the direct link. Thanks to all who made it happen.
I didn’t have the same luck with the Echo discovery. I have 4 Cree Connected lights, 2 WeMo LED lights and a z-wave (Quirky, I think) outlet/switch.
All devices are showing and are working in the ST app, but the Echo discovery only picks up the switch and one of the Cree lights.
I have rebooted the ST hub, the smartphone, and even started over in the Echo app by forgetting all ST devices and doing a new discovery. Still only those same two devices show up.
You do need a virtual switch, but if your locks are controlled by smart things, you don’t need IFTTT for that particular use case. You just use the big switch for hello home actions and have it unlock the door when you flip the virtual switch.
See number 31 under convenience:
You only need IFTTT in the mix if you are connecting to devices which are not controlled directly by the SmartThings.
Just remember with locks that there’s no security, this is a voice input. If you use “Alexa, turn on front door lock” to flip a virtual switch that unlocks your front door, someone could stand outside your house and yell the same thing and the door would unlock.
However, and this may well have been what you were thinking of, one of the big advantages to virtual switches is that you don’t have to assign actions to both the “on” and “off.”
You could set up a virtual switch that locks the door, and never set up anything for echo to use that unlocks the door. Then some stranger yelling could lock your door but they couldn’t unlock it.
Thanks for the reply. And indeed that was the problem; I had forgot to go into “Convenience > My device list” and re-enable those devices there. NooB error, LoL.
I’ve got the server & client running, just no mic for input. Not sure how great it will be without a mic array, but hopefully a viable alternative considering it will be a < $50 “Alexa”.
@nelemansc
I never realized they opened up the AVS portion of Alexa. The api really gives you a lot of power. Maybe we will see ST use this to send voice announcements out of the echo like what can be down with the sonos speakers currently.
So I was reading though the AVS documentation. The way it reads, it looking like you have to hit a button to start listening and stop listening and you wouldn’t be able to use the Alexa or Amazon command. Am I reading that correct?
That’s correct as far as I can see too. It’s more proof of concept as of right now. I breezed right over that portion originally since I didn’t have a mic to begin with. Looks like we will have to wait a bit longer until it’s no longer a developer preview.
Yea. I’ll prob try it out anyways to test. I wonder if I can use my bluemic, which is USB, on the rpi to test being I don’t have a usb-DCA. In the end I would love to have multiple usb-DCAs running off a rpi (one for each room and running each DVA on a separate AVS client) that way every room will have voice control within them, now that would be sick. Only thing that would make that set up better is if you could sync up the echos when playing music.
Let me know how the mic works, I’ll be in the market for some once AVS gets out of preview! I have faith that music syncing between Echo’s is a good possibility with the rate that the Echo team is pushing updates.
Hey Zpriddy, I am trying to use your Nest control skill and I’m getting the 500 Internal Server error. I believe I saw other people having this issue. Am I doing something wrong, or does it no longer work?
Different strokes for different folks. I would like to incorporate the Alexa voice service into my full home audio system with a “mic array” setup with a microphone in each room. I already use Amazon Music to house all my songs so this would just make the whole setup more seamless.
HI I am new to all of this and wanted more information on intergrating Smartthings with HAI OMNIPRO controller.? if you can point me in the right direction that would be great
