I have a Philips Hue Motion Sensor (Outdoor) and use this DTH - hueMotionSensor/hue-motion-sensor.groovy at master · bogdanalexe90/hueMotionSensor · GitHub
Thanks to the person who created this DTH. It had been very useful.
I notice from events that the default DTH configuration is set to poll for temperature, illuminance data frequently (every 5 minutes or so). I have pasted below a snapshot of the events as seen in the IDE.
I have 2 questions.
- Am I right to understand that by keeping the polling interval higher when there is no motion (i.e. more spaced apart), it could potentially extend battery life on the Hue Sensor ?
- Assuming the answer to above question is yes, can anyone help me with what configuration changes need to be done in the groovy file to make the temperature/illuminance polling (when there is no motion) to say 1 hour intervals instead of every 5 minutes or so. I tried changing the configuration parameters in the file to “3600” seconds, but that doesn’t seem to have taken effect. Made me wonder if I updated the wrong parameters. Have pasted below the CONFIGURATION as it is currently (my edited version with 3600 seconds)
EVENTS
2022-10-15 9:20:19.000 AM | illuminance | 205 |
2022-10-15 9:15:22.000 AM | illuminance | 204 |
2022-10-15 9:10:25.000 AM | illuminance | 202 |
2022-10-15 9:05:55.000 AM | temperature | 13.0 |
2022-10-15 9:05:29.000 AM | illuminance | 199 |
2022-10-15 9:00:58.000 AM | temperature | 12.7 |
2022-10-15 9:00:32.000 AM | illuminance | 196 |
2022-10-15 8:55:35.000 AM | illuminance | 192 |
2022-10-15 8:51:05.000 AM | temperature | 12.5 |
2022-10-15 8:50:39.000 AM | illuminance | 189 |
2022-10-15 8:46:08.000 AM | temperature | 12.7 |
2022-10-15 8:45:42.000 AM | illuminance | 180 |
2022-10-15 8:40:45.000 AM | illuminance | 181 |
2022-10-15 8:35:49.000 AM | illuminance | 173 |
2022-10-15 8:30:52.000 AM | illuminance | 166 |
2022-10-15 8:26:22.000 AM | temperature | 12.2 |
2022-10-15 8:25:55.000 AM | illuminance | 161 |
CONFIGURATION (as edited by me to change default max time to 3600 seconds)
CONFIGURATION within groovy file
def configure() {
log.info “### Configure”
// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
// enrolls with default periodic reporting until newer 5 min interval is confirmed
sendCheckIntervalEvent(2 * 60 * 60 + 1 * 60)
// Configure reporting interval if no activity
// - motion - minReportTime 1 seconds, maxReportTime 5 min
// - illuminance - minReportTime 5 seconds, maxReportTime 5 min
// - temperature - minReportTime 10 seconds, maxReportTime 5 min
// - battery - minReport 120 min, maxReportTime 120 min
def configCmds = [
zigbee.configureReporting(MOTION_ALERT_CLUSTER, MOTION_ALERT_VALUE, DataType.BITMAP8, 1, 3600, null),
zigbee.configureReporting(ILLUMINANCE_MEASUREMENT_CLUSTER, ILLUMINANCE_MEASURE_VALUE, DataType.UINT16, 5, 3600, 1000),
zigbee.temperatureConfig(10, 3600, 5),
zigbee.batteryConfig(7200, 7200, 0)
Thanks i n advance.
