Anyone having issues with there PEQ motion sensor? Mne will not update the battery or temp update, it does not have any issues with the motion sensor.
I can removes / add and it will work for awhile but then stop ready…
most of the SmartSense sensors, only update at 11% battery intervals, or 1F/hour intervals. If the change does not exceed that then you will not be updated. I believe the PEQ are similar.
You are PROBABLY seeing normal behaviour, so you need look no deeper.
I wouldn’t call this normal since his temp is also not updating. Are you using the right device type? I am using smartsense motion/temp device type. Also maybe unplug your hub for about 15 mins for zigbee repair to see if that will help.
