I have 4 of these which are essentially rebranded Centralite/SmartThings sensors. They worked fine with Iris, but have been problematic under SmartThings since day 1. They typically just stop reporting temperature or battery but will still report leaks, except 1 which just goes dead. Resetting the sensors will bring them all back online for a period of time. All of the batteries are reporting 88%.
Here’s the weird thing, all 3 out of 4 stopped reporting on Sunday, only 1 continues to report. Anyone using these experiencing any issues? Current firmware is 0x10015100 My Iris-branded leak sensor of the same type works like a champ. I’m guessing it’s a firmware issue; mesh density isn’t an issue with 43 SmartPlugs connected throughout the house.
When I pull and re-insert the battery I’ll see these 2 messages in the IDE:
9:08:13 PM: debug Sending enroll response
9:08:13 PM: debug Refreshing Temperature and Battery
I’m concerned about the enroll response being logged.
I have 8 of them. 6 work consistently, while the other 2 drop off and need the battery removed and re-added periodically. Honestly, not reliable with respect to the function they are designed to serve. The 6 that work consistently are located where the most damage could occur. The other 2, if would be nice to know, but with their location in the basement, it’s less critical (plus there’s another backup there anyway).
I’m not sure how many of these I have, but it is at least 15. I’m on the same firmware as you and I’m not having any issues. I have had a few drop off from time to time, but not recently. Also, I use Simple Device Viewer to alert me if it hasn’t heard from a device in a few days.
@greg I am using simple device viewer to alert me too.
I’ve decided to purchase a replacement for the one sensor located behind the fridge given it’s the hardest one to access to reset. I’ll take that one which also drops off the most frequent of the 4, and see if it’s any better next to the hub.
If it’s behind the refrigerator, it may just be having a hard time getting signal through. Before abandoning that particular one, I would swap that one with one of the other ones that is working, and see if it’s the location rather than the device which is problematic.
I will try swapping it first, thanks for the suggestion. I’m not worried about signal as I have a smart plug for the fridge a few feet above it which I use for energy monitoring and alerting.
