I have a pellet stove that I currently control with a Skytech 3301P wireless remote. The receiver module is basically a millivolt contact relay.
Is there a product or a way to have a zwave switch close a millivolt circuit?
I have 120v behind the stove, so if it exists I plan to plug it in to the 120v and wire the millivolt relay to the thermostat posts on the stove.
I can then use ST to turn it on and off when I want as well as a temp sensor for when the temp in the room hits my setting.
Any ideas or suggestion…
I use the remotec zfm-80 as a dry contact for a gas fireplace. It’s been working smoothly for a year now.
If you want to keep your current switch, that’s not a problem. It wires into an existing switch.
ero4444
(Eric)
3
Include a high-temperature-safety-thermostat that is not networked.
cool, wish they had it as a plug in type…have an outlet not a switch box.
My stove has like 5 safety limit switches.
I am basically creating a thermostat with zwave.
This stove is in my finished basement and it does not drop below 60 down there.
I have been using my thermostat to control and maintain temp when I want it…but I have no way to shut it off without being home and going downstairs.
