All,
I create a new app and I have shared it. The app waits for a double tap on a specific switch and if you double tap down it will change a mode(arm system or sleep mode). Then it will do the opposite if you double tap up(disarm or switch to home mode). This is only my second app and I’m wondering if someone could review it to determine if I have done anything incorrectly. Thanks in advance for the feedback.
-Jeremy
A quick note: What concerns me about this app is the fact that I’m seeing this error on the console log files:
10:07:28 PM: warn No event handler found for mode event 'At Home Night'
* Change Mode On Double Tap
* Author: Jeremy R. Whittaker
* Date: 2013-10-26
* This mode change works great if you use a switch in your room to arm/disarm your system.
* When you go to bed you can double tap down and set mode to sleeping(arm).
* When you wake up you can simply double tap up to set the mode to day time(disarm) to disable your alarm.
preferences {
section("When this switch is double-tapped...") {
input "master", "capability.switch", title: "Where?"
section("Double tap up change to this mode") {
input "upMode", "mode", title: "Up Mode?"
section("Double tap down change to this mode") {
input "downMode", "mode", title: "Down Mode?"
section( "Notifications" ) {
input "sendPushMessage", "enum", title: "Send a push notification?", metadata:[values:["Yes","No"]], required:false
input "phoneNumber", "phone", title: "Send a Text Message?", required: false
def installed() {
log.debug "Current mode = ${location.mode}"
subscribe(master, "switch", switchHandler, [filterEvents: false])
subscribe(location, modeChangeHandler)
def updated() {
unsubscribe()
def switchHandler(evt) {
log.info evt.value
// use Event rather than DeviceState because we may be changing DeviceState to only store changed values
def recentStates = master.eventsSince(new Date(now() - 4000), [all:true, max: 10]).findAll{it.name == "switch"}
log.debug "${recentStates?.size()} STATES FOUND, LAST AT ${recentStates ? recentStates[0].dateCreated : ''}"
if (evt.isPhysical()) {
if (evt.value == "on" && lastTwoStatesWere("on", recentStates, evt)) {
log.debug "detected two taps, disarming system"
takeUpActions()
} else if (evt.value == "off" && lastTwoStatesWere("off", recentStates, evt)) {
log.debug "detected two taps, arming system"
takeDownActions()
else {
log.trace "Skipping digital on/off event"
private send(msg) {
if ( sendPushMessage != "No" ) {
log.debug( "sending push message" )
sendPush( msg )
if ( phoneNumber ) {
log.debug( "sending text message" )
sendSms( phoneNumber, msg )
log.debug msg
def takeUpActions() {
log.debug "changeMode, location.mode = $location.mode, newMode = $newMode, location.modes = $location.modes"
if (location.mode != upMode) {
if (location.modes?.find{it.name == upMode}) {
setLocationMode(upMode)
send "Double tap up has changed mode to '${upMode}'"
else {
send "Double tap up has tried to change to undefined mode '${upMode}'"
def takeDownActions() {
if (location.mode != downMode) {
if (location.modes?.find{it.name == downMode}) {
setLocationMode(downMode)
send "Double tap down has changed the mode to '${downMode}'"
else {
send "Double tap down has tried to change to undefined mode '${downMode}'"
private lastTwoStatesWere(value, states, evt) {
def result = false
if (states) {
log.trace "unfiltered: [${states.collect{it.dateCreated + ':' + it.value}.join(', ')}]"
def onOff = states.findAll { it.isPhysical() || !it.type }
log.trace "filtered: [${onOff.collect{it.dateCreated + ':' + it.value}.join(', ')}]"
// This test was needed before the change to use Event rather than DeviceState. It should never pass now.
if (onOff[0].date.before(evt.date)) {
log.warn "Last state does not reflect current event, evt.date: ${evt.dateCreated}, state.date: ${onOff[0].dateCreated}"
result = evt.value == value && onOff[0].value == value
else {
result = onOff.size() > 1 && onOff[0].value == value && onOff[1].value == value
result
