I have my hub where my home entertainment setup is, all my equipment is black. Was thinking about painting the hub black so it wont stand out as much.
I know that this may void the warranty but will it cause it to fail to communicate with z-wave devices around my house? Like deminish the signal in any way?
Let me know if anyone out there done this or through about doing it.
Should not be a problem, as @Mike_Maxwell states! You might be on to the next v3 wave of ST design, brilliant external Hub colors! I would purchase the “Military Camouflage” colored V3 unit that has stealth technology built in
There is a small chance it could reduce signal strength, depending on the exact materials of the paint. Metallic paints have been known to cause signal drop off on equipment.
All of that said, I would approach this differently. I would just get a black plastic electrical box, cut the back off it, and put the SmartThings hub in that. Cheap and easy.
If you get one from a supply house, look at “project boxes” or junction boxes. These will usually be better made and easier to modify then storage boxes. And that way if you decide to move it to someplace where white would work better, you just take it out of the box. Since smartthings doesn’t have any indicator lights for everyday use, you can hide it completely.
The following is just an example from a good brand, the sizing isn’t quite wide enough on this one unless it’s okay for an inch or so of the hub to be sticking out of the back. You’ll be able to find bigger ones, I just didn’t spend much time looking. Also, it’s best to take the hub to a supply house and make sure the fit is right. A lot of these will have interior features which may change the inner dimensions, and that way you can also check for color and translucency.
I painted mine using flat black spray paint. I just painted the top part. I didn’t even cover the led, just painted over it. The led shines through fine. I also painted my lutron hub the same way. Once again, the paint allowed the led to shine through.
If you paint it with black plati dip once it dries it can easily be peeled back off to reveal the white body color once again.
MULTIPURPOSE RUBBER COATING
Plasti Dip is an air-dry, specialty rubber coating. In fact, it’s the original peelable, flexible, insulating, non-slip, durable rubber coating. The Plasti Dip product line provides a wide range of coating solutions from automotive customization to home improvement. With over 50 colors and enhancers of Plasti Dip, including a Create Your Color Kit, the possibilities are endless!
