The fact that it says Disarmed by Elk means that information is getting through, does the alarm definitely finish the exit delay beeps (i.e. the time it normally waits for you to leave the house)? If you scroll down to one of the sensors do you see any of them change to active when you get motion? (that might be an easier one to test).
Maybe send a screenshot of the actual device info page on the IDE (so I can see the information is correct there).
Also can you keep the serial connection open on the PC at the same time since the connection between the two would be useful.
Hello, The alarm does finish the count down. I’m not at home to trigger a zone but below is an image of the device info. I’m using the hex ip address of the Node.
Just checking that the Node IP address is currently 192.168.1.80?
After the alarm finishes the countdown can you visit the Node website and go to the Status page? Hopefully there it should say Arm Away/Home.
Otherwise I agree that looks correct, what is your network setup? Do you just have a single router/modem from the ISP, or do you have multiple access points/routers?
I have Google Mesh network with alarm, smartthings, and Node all being assigned reserved IP’s. Elk and Smartthings come off of the same network switch off of one of the mesh AP’s. I do have quite a bit of devices on my network. I did change my network ID for the node to the HEX format. I am now getting the correct status when checked through the webpage so its progress.
There’s a dropbox link above. If I can paste right, it is here
I’ve been tied up a lot lately with work, but I am excited about all the development progress! I can’t wait to try it!
It was my understanding that the dropbox file was the updated firmware for the node. I have just been using github for the ST app. Now you have me wondering if I using the right app!
Yes, the Github code should be fine for the ST Device Handler. Im trying to ensure this solution works with my existing device handler since that saves me a ton of work! This project is reaching the end of my time limit now as it has taken ages to get this far!
I have done one more update which should show all the zone names after you first request the /status or /refresh page from the NodeMCU. I suggest doing this on your PC to start with as it will be easier to check progress. It should give a message that it needs a minute or so to collect all the information from Elk (I have no idea how long it will take but think 1 minute is definitely safe). After this is complete then you can hopefully go to /getzonenames and it should return the zone names… (duh!!) Then you can try pressing the ‘Get Zone Names’ button in ST.
However, this still doesnt resolve the fact that ST is not receiving the actual JSON messages from the NodeMCU for some people, for that I would need to see the serial logs and the IDE logs in parallel.
Do you have a protected/segregated WiFi network that might be blocking the packets from being sent to ST? Otherwise it seems that everything should be working…
I have updated again so it should try to request alarm status on boot, but just seeing the unknown message doesnt mean it isnt working. Have you got zone names now? Did you get the message about waiting 1 minute?
For me to work out why that is you’ll need to connect it to serial and give me the logs. Are they all numbered sequentially? Lots of things potentially at cause here it could be the alarm using a funky format, it could be the type of zones, it could be my code converting something badly (especially curious as it stops at 10).
