Got these contact switches because they are small and indescrete. Attempted to pair and they come up as “Zigbee Thing” .
Went to ST site and attempted to change the driver to “Zigbee Contact” and “Ensure driver you are trying to change to has valid fingerprint match”
Tried for a few hours deleting and adding back in to no avail.
Throw these in the woods or something I’m missing.
Try @Mariano_Colmenarejo “Zigbee Contact Mc” driver. You can find it at:
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
If that doesn’t work post the fingerprints (Mfg. Code & Model) and ask Mariano if he can add them to his driver. You can find the fingerprints using the Advance Web App Samsung account .
I did try that. I downloaded the MC driver and attempted to adopt it to the device. No luck
Thanks for the reply
I did find the model number though
Ouvopo x003yvaspz
B0C2HX5W7R
I get it. The signature is in the header of the driver;
Name Zigbee Contact Mc
Version 2022-12-24T14:18:56.276630174
deviceLabel: TS0203 Close Sensor
manufacturer: _TZ3000_n2egfsli
model: TS0203
deviceProfileName: contact-battery-profile
It looks for this label for a handshake on the device.
Hi @Pete_Carter
If those are your fingerprints, this should work
They are not.
This is the header from your other program that failed to work with my hardware.
I was figuring out why it wouldn’t work and what he error code meant.
My friend fingerprints are listed in the previous post.
Hi,
In order to add to the drive, please pair with the zigbee thing Mc driver to be able to see all the data of the device
It is paired now as a thing. I’ll cut and paste the data this evening.
When paired, this is what it shows on the hub;
Device Label
Zigbee Thing
Device Name
zigbee-thing
Device ID
af3f1c8d-c696-40be-98ff-ef6e94f80d6e
Device Profile
zigbee-thing
Location
My home
Room
Living room
Hub
Hub
Driver
Zigbee Thing
Manage Hub’s Drivers
Network ID
FBB4
Created
Oct 21, 2023, 7:23 PM
Model
SNZB-04
Type
ZIGBEE
Execution Location
Local
Presentation ID
bc813f60-efa1-3d89-896d-93ef64cf89c8
Pete_Carter:
Model
SNZB-04
Manufacturer Code is missing.
It is two lines below
@Pete_Carter
If you want me to add devicr you have to publish the manufacturer, as I told you in the previous post.
I would like to be ewelink or sonoff
I have the same sensor. The information you need is as follows:
Model: SNZB-04
Manufacturer Code: eWeLink
This device was added three days ago
Hi @manchester3fan
Added to this driver version.
For device fine configure you must remove device and pair with this new driver version. Driver change not works fine
Version 2023-10-27T14:27:11.038825764
- id: "eWeLink/SNZB-04"
deviceLabel: eWeLink Open/Closed Sensor
manufacturer: eWeLink
model: SNZB-04
Thanks very much! Haven’t been able to get back to this because of …life . lol
Appreciate it!
